[Solved] Windows 10 Pro 64bit - Issues with Milesight VMS Lite Autostart, Task Scheduler & Batch File
mlassota 13731 16
How can I make Milesight VMS Lite start automatically on Windows 10 when Task Scheduler and a batch file initially fail?
Milesight VMS Lite can be started automatically by using a properly quoted batch file placed directly in the Startup folder, not just a shortcut to it [#17114663] Because the install path contains spaces, the executable path must be in quotes, and if you use a task or shortcut you should also fill in the correct “Start in” folder [#17114026] A working batch example is `@ECHO OFF`, then `CD ",` `CD "Program Files (x86)\Milesight VMS Lite"`, then `START "" "C:\Program Files (x86)\Milesight VMS Lite\Milesight VMS Lite.exe"`, then `EXIT` [#17114826][#17115325] The empty `""` after `START` is important; without it the program may not launch correctly [#17115325] After doing this, the program started automatically after reboot [#17114663]
  • #1 17113752
    mlassota
    Help: 11
    Rate: 85
    I am asking my colleagues for help in the following matter
    Windows 10 Pro 64 bit used as a home FTP, DLNA server and camera recorder. I have a problem with the latter. As VMS software I use Milesight VMS Lite
    The program easily runs "from the desktop", works and does not create any problems.
    However, I can't make it start automatically when Windows starts
    I tried the Task Scheduler, adding both common and user to the autostart to check the options in the program (there is one)
    Program permissions set to maximum - full access
    Creating a batch file also gives no result - The program does not start from the bat file.
    There is a strange situation when you try to start using Task Scheduler
    The task is created correctly but when you try to edit it, an error message pops up "There was an error regarding the task. The message is error: At least one of the specified arguments is not valid.
    I have already exhausted all my ideas so I am asking you for help in making this autostart ...
  • #2 17113800
    perzan
    Rate: 8
    Can you put the contents of the "Target" field from the properties of the shortcut on your desktop?
    This can tell us something.
    P.
  • #3 17113809
    mlassota
    Help: 11
    Rate: 85
    Of course
    "C: \ Program Files (x86) \ Milesight VMS Lite \ Milesight VMS Lite.exe"
    Unfortunately, I can't upload the screen - at the moment I have access only through VNC and there is no such option :(
  • #4 17113975
    Matuzalem
    Help: 1653
    Rate: 1101
    Yes, "I think out loud" or wouldn't it be possible and using Windows 10 to run the program as a service using sc.exe * - https://support.microsoft.com/pl-pl/help/251192/how-to-create- windows-a-service-by-using-sc-exe
    A solution as old as the tool, but it may work. Of course, on the condition that the program itself can be pressed into such a framework.
    * https://www.microsoft.com/en-us/download/details.aspx?id=17657
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
    perzan
    Rate: 8
    The first thing that catches the eye is the spaces in the directory and file names.
    If you want to use it in a batch file, it must be rewritten with quotation marks.
    In the properties of the new shortcuts you must also specify "Start in:" identically as in the original shortcut.
    Similarly, if you create a task in the schedule, in particular with a batch file, you must fill in the "Start in" field, otherwise it will invoke the program being in the% WINDIR% \ System32 or% USERPROFILE% directory if you release it in the schedule on your account.
    Have you looked at the "Compatibility" tab or something is not turned on there?
    But above all, quotation marks are the most common windows ill.
    Methuselah: not every program will walk as a service.
    P.
  • #6 17114223
    Matuzalem
    Help: 1653
    Rate: 1101
    Hence in his previous post, among others and this:
    I put the sentence (hoping that this is a clear enough indication of the restriction you wrote about), but you could not see that.
    Doradztwo podatkowe
  • #7 17114663
    mlassota
    Help: 11
    Rate: 85
    In fact, the quotation marks caused the batch file to run the application
    I placed it in the autostart directory - the bat file itself must be placed - placing a shortcut to it does not give the desired effect
    After restart, the program started automatically
    There remains a slight inconvenience in the form of a running console window ... but that's ... a tiny problem - it can even be so unless you have an idea
  • #8 17114745
    clubs
    Help: 629
    Rate: 406
    Write an exit for this whip
  • #9 17114783
    mlassota
    Help: 11
    Rate: 85
    Wish it were that simple...
    I started my adventure with DOS 5.0 ...
    Exit will be effective but only after the application is finished in the line above ...
    And then it will actually close the console
    perzan
    Rate: 8
    Type in the .bat file like this:
    START "C: \ Program Files (x86) \ Milesight VMS Lite \ Milesight VMS Lite.exe"
    And to make it look better, write something like this:
    @Echo. OFF
    C:
    CD \
    CD "Program Files (x86) \ Milesight VMS Lite"
    EXIT
    The console window should disappear and the program work.
    This extended version should also work if you make a shortcut in the autostart instead of loading a file there.
    Good luck.
    P.
  • #11 17114828
    clubs
    Help: 629
    Rate: 406
    If you do not use start / w it will close the console after "opening" the program
  • #12 17114942
    mlassota
    Help: 11
    Rate: 85
    Unfortunately, adding START before the execution line causes that the line does not run - the program does not start and the console does not close. Only a clean execution line runs the program
    Maybe there is something dug up in W10 ...
    clubs
    Help: 629
    Rate: 406
    mlassota wrote:
    Unfortunately, adding START before the execution line causes the line not to be executed
    So this whip doesn't start your program?
    Code: Dos
    perzan
    Rate: 8
    clubs: Good, with an empty window name starts, I don't want to. Nature curiosity, what's the name of the window to run the program? :(
    What's better, if I start the program without a space in the name of the directory by starting it, it starts without an empty window name, and if there are spaces in the exeka name itself, it won't start, although the exeka name is in quotation marks. Hmmm ... be smart here on MS. :(
    mlassota: The console you are left with is not the one from which the program is called, but a new one that opens instead of the program. In Win7 I have the same effect.
    The clubs code should work. They only need to be these two quotation marks before the file path.
    P.
  • #15 17116465
    mlassota
    Help: 11
    Rate: 85
    welcome back
    Strange things are happening with this batch file
    It is removed from the autostart directory - both shared and user-defined
    My guess is that some anti-virus crashes it or windows itself. Avast doesn't really do that because I have added the entire directory to exclude
    If there is no start "" only the execution line itself - everything is ok, it doesn't disappear from the autostart, it starts up leaving the console as if from the desktop it fires with the start, it works beautifully when I throw it into the autostart - it disappears
    And get here be smart :)
    Thank you all for great help !!!
  • #16 17116666
    clubs
    Help: 629
    Rate: 406
    Then add this whip to the register under "run"
  • #17 17116737
    mlassota
    Help: 11
    Rate: 85
    Creating a batch file satisfactorily (though, as I wrote earlier, not quite perfect) solved the problem
    thank you all
The discussion revolves around issues with autostarting Milesight VMS Lite on Windows 10 Pro 64-bit. The user initially faced challenges in getting the software to launch automatically at startup, despite it functioning correctly when started manually. Various solutions were proposed, including using Task Scheduler, creating batch files, and running the program as a service. Key points included the importance of using quotation marks in file paths, ensuring the "Start in" field is correctly set, and potential conflicts with antivirus software. Ultimately, the user found success by placing the batch file directly in the autostart directory, although a console window remained open during execution. Further suggestions included adding the program to the Windows registry under "run" for a cleaner startup experience.
TL;DR: 260-character path limits apply—"In the Windows API, the maximum length for a path is MAX_PATH, which is 260 characters." Quote spaced paths, set Task Scheduler "Start in," or use a Startup .bat with START "" to close the console; Registry Run is a fallback. [Naming Files, Paths, and Namespaces]
Why it matters: This helps Windows 10 users auto-start Milesight VMS Lite reliably for uninterrupted recording.
How do I auto-start Milesight VMS Lite reliably on Windows 10?
Use a simple batch file and place it in Startup. 1) Create a .bat containing the quoted EXE path. 2) Put the .bat itself (not a shortcut) into the Startup folder. 3) Restart and confirm VMS Lite opens. This method worked even when shortcuts and Scheduler failed. It may leave a console window; see the next answer to hide it. [Elektroda, mlassota, post #17114663]
How do I hide the console window when launching via a batch file?
Call the app with START and an empty title, then exit. Example: start "" "C:\Program Files (x86)\Milesight VMS Lite\Milesight VMS Lite.exe" followed by exit. Do not use /W if you want the console to close immediately. As one expert noted, "If you do not use start / w it will close the console after 'opening' the program." [Elektroda, clubs, post #17114970]
Why won’t my Task Scheduler task launch Milesight VMS Lite?
Incorrect quoting or a missing Start in directory commonly breaks tasks. Quote the full path to the EXE and set Start in to the application’s folder. Without Start in, Scheduler can try launching from System32 or your profile, and the app fails. As one expert put it, “quotation marks are the most common windows ill.” [Elektroda, perzan, post #17114026]
What’s the correct way to quote a path with spaces?
Wrap the entire path in double quotes. Example: "C:\Program Files (x86)\Milesight VMS Lite\Milesight VMS Lite.exe". Apply this in batch files, shortcuts, and Task Scheduler’s Action fields. “But above all, quotation marks are the most common windows ill.” Consistent quoting prevents mis-parsing and launch failures. [Elektroda, perzan, post #17114026]
What should I put in Task Scheduler’s Start in (optional) field?
Set it to the program’s installation folder. Example: C:\Program Files (x86)\Milesight VMS Lite. This ensures the process starts with the correct working directory. Otherwise, Windows can default to System32 or your user profile, causing file resolution issues at launch. [Elektroda, perzan, post #17114026]
START does nothing when I try it—what did I do wrong?
START treats the first quoted string as the window title. If you omit a title and your path is quoted, it may not launch. Provide an empty title before the path: start "" "C:\path\app.exe". This resolves the no-launch symptom with spaced paths. [Elektroda, perzan, post #17115325]
A shortcut in Startup doesn’t work—should I put the .bat itself?
Yes. In this case, placing the .bat file itself in Startup worked, while a shortcut did not. Using the direct .bat avoids resolution or permission quirks that sometimes affect .lnk processing at logon. [Elektroda, mlassota, post #17114663]
My .bat keeps disappearing from Startup—what should I check?
Check antivirus and security policies. One user observed the .bat being removed when using START, but not when calling the EXE directly. Add exclusions or simplify the script if it triggers cleanup. If removal persists, consider the Run registry method. [Elektroda, mlassota, post #17116465]
Can I run Milesight VMS Lite as a Windows service instead of at logon?
Only if the app is service-friendly. UI-bound apps often fail as services. As one expert cautioned, “on the condition that the program itself can be pressed into such a framework.” Test carefully, or prefer Startup/Run for GUI recorders. [Elektroda, Matuzalem, post #17114223]
Why does it start from the desktop but not at boot/logon?
Environment and working directory differ at boot/logon. Missing quotes or Start in can break launches outside your desktop session. Fix by quoting the path and setting Start in to the install folder, or use a minimal Startup .bat. [Elektroda, perzan, post #17114026]
How do I add Milesight VMS Lite via the registry Run key?
Use the Run key to trigger the app at user logon. Create an entry under the Run registry location that points to your EXE or .bat. This bypasses some Startup folder quirks and keeps autostart simple. [Elektroda, clubs, post #17116666]
Can long paths or special characters break autostart or tasks?
Yes. Windows legacy MAX_PATH is 260 characters, which can break launches. Keep paths short and simple. If you hit this limit, shorten folder names or relocate the app. This reduces argument parsing errors in tasks and scripts. [Naming Files, Paths, and Namespaces]
