Vectra C 1.8 2002 - Falling Clocks, ABS Lights, Radio & Windows Issues: Alternator or Battery?
kubsonn93 8616 15
Why do my Vectra C's clocks drop out and disable the radio, windows, turn signals and ABS lights intermittently?
This looks more like a communication/CAN or connection fault than a bad alternator or battery. Start with a full scan of all modules and read the fault codes, because the likely suspects are the instrument cluster, CIM and ABS/communication errors [#16822469][#16822470] One user reported the problem mainly in the morning or when it was wet, with communication-related faults, which points to an intermittent connection rather than charging voltage [#16822567] Another fixed a similar issue by cleaning the meter/instrument-cluster power supply connector cube [#16833920] Also check the ignition switch for intermittent contact, and consider the CIM if it has been repaired or modified before [#16833732][#16834056]
  • #1 16822323
    kubsonn93
    Hello, I have a vectra c 1.8 2002.
    I have a problem with falling clocks, when the problem occurs, the directions do not work, the radio, windows. The ABS lights are on, the engine is still charging. After the car is turned off, everything returns to normal. The battery is new, is it the fault of the alternator, please help?
    sk700
    Help: 173
    Rate: 420
    Looks like communication problems. You would have to start with reading errors ...
    leonek4
    Help: 104
    Rate: 638
    There can be several reasons (meter, cim, abs problems). The tips fall every time after starting the car or occasionally?
    First, do a thorough computer diagnostics of all modules and provide errors.
  • #4 16822567
    kubsonn93
    Symptoms are most common in the morning when it's wet.
    Errors
    P1616-immob signal incorrect
    P0501 - Vehicle own speed sensor discontinuous
    P0500 - Pred sensor self discontinuous
    B1000 - replace the airbag controller
    B3055 - transponder damage
  • #5 16828433
    tomek7040
    Rate: 8
    And what, buddy, have you figured out what's bothering you with this vectra? I got the clocks after the first frosts, I don't know if it has any connection.
  • #6 16833633
    tomek7040
    Rate: 8
    Unfortunately, I also need help, VC 2005 1.9cdti 150 km caravan, for a few days my speedometer and tachometer tips have dropped sometimes
    no lights come on. I will add that after resetting the errors, everything is ok for a cold start again, after the tips fall, it seems to me that when the cold car is restarted, the auxiliary heater freaks out, it will turn on for a moment, will not turn on at all - you can not hear it.
    the errors I read with the op-com are
    CIM
    U2103-0f no communication with CAN-Bus (low speed)
    instrument
    U2105-7f CAN-Bus no communication with the ECM
    SDM airbag
    U2139-00 incorrect data from CIM
    PAS Park pilot
    U2139-00 CAN-Bus no communication with the CIM
    The car is still driving normally, it started after the first frost.
    In the auxiliary heater, I still read the error B1000-0f relay failure, but this one occurs less frequently and I do not know if it is related to the above errors.
    What can it be and how to deal with it?
  • #7 16833732
    Alfred_92
    Help: 148
    Rate: 706
    I would check the ignition switch (fumble a little with the ignition key and see if there will be any reaction).
  • #8 16833873
    kubsonn93
    The alternator is replaced, February corrected, it is a little better because the clocks drop and no directions, the rest works properly only in the morning. Where to look next?
  • #9 16833920
    lulus68
    Rate: 12
    hello I had the same wine supply cube at the meter must be cleaned
  • #10 16833994
    tomek7040
    Rate: 8
    My friend, me and Kubson, we soldered the meters, nothing helped, I already throw out the errors that I wrote earlier on the meter.
    Tell me about the reaction of this ignition switch you mean, Cim made about half a year ago.
  • #11 16834012
    tomasz0703
    Help: 69
    Rate: 489
    What does cim made about half a year ago? You have surely cut on 2j74y and here is the problem.
  • #12 16834056
    tomek7040
    Rate: 8
    It was repaired by a mechanic when I bought the car, directions and a disco on the meter did not work properly. Can you make it a little brighter? Explain what this means with the cim you mentioned. And how can you be so sure it is?
  • #13 16837879
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    What does it mean Cim made ????? - exchanged for another ??? CPU replaced ??? unfortunately, sometimes exchanging for another only works.
  • #14 16837941
    tomek7040
    Rate: 8
    Made - or repaired ... Unfortunately, I don't know, it was repaired by mechanics. However, I think I have one more suspect, I have disconnected the engine heater, I will watch what happens.
  • #15 16862959
    kubsonn93
    I still have a problem with vectra. In the morning, when the engine is cold, the clocks drop, when the problem occurs, the radio directions do not work, the charging lamps, abs, airbags, manual and reserve flashes, the rest is good, the engine works without changes. When I turn off the car and restart it, everything is fine until the clocks drop again, when the engine heats up to the right temperature, nothing happens.
    Power steering pump new, alternator regenerated, clocks corrected, cold February, all fuses checked, loading is no load 14.3 at a load of 13.5, with the maximum turn of the steering wheel drops to 13. All cubes checked clean. Where else to look if it is the fault of the cim on the steering wheel but that it fires without any problem?
  • #16 16863833
    tomek7040
    Rate: 8
    For me, when Cim was broken, there was a steering wheel with an exclamation mark, the turn signals did not bounce - you had to turn the steering wheel harder to bounce, and basically that ... Nothing else happened ... .. For me the stove controller gave it a hard time, I sent it for regeneration, now I'm waiting for them to do it, nothing is wrong with the car. Where are you from Kubson? And ok ... Lublin ... Far away from Krakow ...
The discussion revolves around issues experienced with a 2002 Vectra C 1.8, including falling clocks, malfunctioning ABS lights, and non-operational radio and windows, particularly in cold conditions. The user suspects the alternator or battery as the cause, despite having a new battery. Various responses suggest potential communication problems, the need for thorough diagnostics, and checking components like the ignition switch and CIM (Central Interface Module). Error codes such as P1616, P0501, and B1000 were noted, indicating issues with the immobilizer, speed sensor, and airbag controller. The user has replaced the alternator and checked fuses, but problems persist, particularly when the engine is cold. Further investigation into the CIM and other electrical connections is recommended.
TL;DR: Cold-morning CAN faults can drop gauges and kill indicators; one owner measured 14.3 V no‑load and 13.5 V under load. “Loading is no load 14.3 at a load of 13.5.” [Elektroda, kubsonn93, post #16862959]
Why it matters: This FAQ helps Vectra C owners quickly isolate alternator, CIM, cluster, and CAN-bus issues that cause falling clocks and ABS lights.
What symptoms point to CAN communication faults on a Vectra C?
Tell‑tales include falling gauges, dead indicators, ABS/airbag lamps, and temporary recovery after restart. Owners also log U2103/U2105/U2139 across CIM, instrument, and airbag modules. Cold or wet mornings often trigger events. When warm, symptoms fade. This pattern suggests low‑speed CAN instability rather than a steady power failure. “The car is still driving normally,” even while gauges drop, which also aligns with comms loss rather than engine control failure. [Elektroda, tomek7040, post #16833633]
Could a healthy battery still show these issues?
Yes. One case used a new battery yet saw falls in the cluster and loss of indicators and radio. The engine kept charging, and a key‑off reset restored operation. That points away from battery State‑of‑Charge and toward intermittent connection or CAN integrity problems affecting body modules. [Elektroda, kubsonn93, post #16822323]
Are these problems alternator related?
Not always. After a regenerated alternator, one owner still had morning dropouts: gauges fell and indicators died until warm. Measured voltage was 14.3 V no‑load and ~13.5 V with load, which is adequate. Focus shifts to wiring, cluster connector, ignition switch, and CIM when charging values are in range yet symptoms persist. [Elektroda, kubsonn93, post #16862959]
What first diagnostic step do experts recommend?
Start by scanning every module and reading stored DTCs. That establishes whether the fault is communication, sensor, or module level. As one advisor put it, “do a thorough computer diagnostics of all modules and provide errors.” Scan with OP‑COM or equivalent and note U‑codes and P‑codes. [Elektroda, leonek4, post #16822470]
What is the CIM, and why does it matter here?
CIM is the Column Integration Module that handles steering‑column electronics and mediates CAN traffic for several body functions. Faulty CIMs can cause indicator oddities, steering‑wheel symbol warnings, and instrument dropouts. Members reporting U2139 and indicator issues often investigate CIM condition, coding, and prior repairs. [Elektroda, tomek7040, post #16833633]
How do I check the ignition switch for involvement?
A worn ignition switch can interrupt accessory power or wake‑up lines, mimicking CAN faults. One tip is to gently wiggle the key and watch for cluster or indicator changes. If reactions occur, replace the switch or test voltage at switch outputs during the event. [Elektroda, Alfred_92, post #16833732]
Can the instrument cluster itself cause the ‘falling clocks’?
Yes. Oxidation or poor contact at the cluster power connector can drop the gauges. A member fixed the same symptoms by cleaning the cluster supply plug (“cube”). If solder reflow didn’t help, inspect, clean, and reseat the connector with contact cleaner. [Elektroda, lulus68, post #16833920]
Why do problems appear on cold, wet mornings?
Moisture and low temperatures increase contact resistance and marginalize failing modules. Owners report most dropouts during first cold starts and after frost. Warmth restores stable operation. This matches intermittent connectors, ageing clusters, and CIM sensitivity when cold. [Elektroda, kubsonn93, post #16822567]
Could the auxiliary heater or HVAC electronics be the culprit?
Possibly. One owner saw dropouts begin with first frosts and later linked disturbances to the auxiliary heater controller. After sending the heater controller for regeneration, the car behaved normally during testing. Edge case: heater faults can pollute the bus when cold. [Elektroda, tomek7040, post #16863833]
I see P1616, P0500/P0501, B1000, and B3055—what do they indicate?
That mix spans immobilizer signal, vehicle speed sensing, airbag controller replace flag, and transponder damage. Together with morning failures, it suggests a shared communication or power integrity issue rather than four unrelated part failures. Clear codes, reproduce when cold, and re‑scan to see what returns. [Elektroda, kubsonn93, post #16822567]
What charging numbers should I expect during testing?
In a reported good‑charge case, voltage measured ~14.3 V no‑load, ~13.5 V with electrical loads, and ~13.0 V at full steering lock. Those values did not prevent morning dropouts, indicating charging wasn’t the root cause there. Use similar checkpoints to rule out supply faults. [Elektroda, kubsonn93, post #16862959]
How do I perform a quick three‑step cold‑start diagnosis?
  1. Scan all modules cold; record U‑ and P‑codes across CIM, IPC, SDM, and Park Pilot. 2. Verify charging at idle with and without loads; note voltage sag. 3. Reseat and clean the instrument‑cluster power connector; recheck. If symptoms persist, inspect ignition switch and CIM. [Elektroda, leonek4, post #16822470]
Will replacing the alternator always fix the issue?
No. One case improved slightly after alternator replacement, yet gauges and indicators still failed in the morning. That outcome points to wiring/connectors, ignition switch, cluster, or CIM. Do not assume the alternator is the sole cause when DTCs show CAN communication faults. [Elektroda, kubsonn93, post #16833873]
Do restarts masking the fault mean the car is safe to drive?
A restart often restores instruments temporarily, and the engine can run normally. However, driving without indicators or with ABS warnings is unsafe. Treat the vehicle as impaired and diagnose the root cause before regular use. “The car is still driving normally,” but fix the comms fault. [Elektroda, tomek7040, post #16833633]
What if my CIM was ‘repaired’ previously but issues persist?
Clarify what was done: replacement, CPU work, or eeprom cutting noted by members. Prior non‑OEM fixes can leave latent faults. If indicators misbehave and U‑codes persist, test with a known‑good CIM or pursue professional repair with proper programming. [Elektroda, tomasz0703, post #16834012]
What do helpers recommend before swapping expensive parts?
Community advice is consistent: read errors first, then verify communications and power at modules. Clean the cluster connector, evaluate the ignition switch, and only then consider CIM or alternator work. Quoting a helper: “Looks like communication problems. You would have to start with reading errors ...” [Elektroda, sk700, post #16822469]
