Unfortunately, I broke the display on my Xperia z3c. LCD whole, not tipped, but there is no touch. I'm not going to play peeling off the digitizer, but I plan to replace the display. And here the question arises - can you recommend one? I went to the allegro for about 160 ... 200 PLN LCD without frame. Theoretically original, however, it seems to me that it is simply Chinese called the original. The question is: is it profitable? I will say this, I do not care for 100% the same color quality, brightness or viewing angles, but the difference must be minimal. However, the touch must be correct. You've got it
SzK.7
SzK.7
