SONY Xperia z3 Compact - no response to the navigation keys and the pull-down ba
Domin21 3873 7
  • #1 17337201
    Domin21
    Help: 9
    Rate: 52
    The navigation keys (back, home and the third) do not work on xperia. Also, the pull-down menu does not work.
    The phone was still working in April (then I put it on the shelf). Before putting it away, the phone was working (it had problems with the drop-down bar, but the launcher made me think - but it did work). The navigation keys worked fine.
    Full-surface touch only works in the areas previously described.
    I downloaded the latest official software (I thought the launcher was freaking out). But it didn't help.
    Does the touch start raining or the problem is different?
    Thanks for the help.
    Greetings.
  • #2 17337933
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Another LCD + digitizer to substitute, I bet that's it.
  • #3 17337975
    fonexpl
    Level 4  
    Rate: 68
    In my opinion, it is the fault of the touch. A touch to replace.
  • #4 17338728
    Domin21
    Help: 9
    Rate: 52
    But on the service menu, the bar develops better when you try to touch it.
    However, when restarting to factory with the initial settings, the first screens, the lower bar works in the lower right corner
  • #5 17338951
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Substitute another fullset.
  • #6 17340366
    Domin21
    Help: 9
    Rate: 52
    The touch is glued to the display on this phone or not?
    Can I replace the touch only or only the touch + display set?
  • #7 17340402
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    The digitizer itself can be replaced, but you need experience, patience and skill.
  • #8 17340413
    Domin21
    Help: 9
    Rate: 52
    So it's on the glue of the loca.
    Added after 5 [hours] 16 [minutes]:
    And is there a program that will turn my camera button into a reverse button?
The discussion revolves around issues with the Sony Xperia Z3 Compact, specifically the non-responsiveness of the navigation keys and the pull-down menu. Users suggest that the problem may be related to the touch digitizer, with recommendations for replacement. The author notes that the touch functionality improves in certain areas during service menu tests and after factory resets. Queries about the feasibility of replacing the touch screen separately from the display are raised, with responses indicating that while it is possible, it requires skill and experience due to the components being glued together. Additionally, there is a request for software solutions to repurpose the camera button.
