Sony Xperia Z2 (D6503) Display Non-Functional Post-Replacement: Could a Broken Ribbon be the Cause?
Loginovsky 4086 9
  • #1 16336212
    Loginovsky
    Hello, in my Xperia Z2 (D6503), the display tape broke recently, it cannot be replaced, so I bought the entire display with a frame used to play screen replacement and the like. The display with the frame was purchased, used from the allegro, original, I changed everything and installed it properly and the display does not work. The display is probably functional because the seller checked it before shipping. My only idea why the display may not work is the main tape ribbon marked in the photo, which broke when you moved it. However, it seems to me that it does not matter much to the operation of the display, except that it has been glued so that it should work. All other parts are 100% functional, the phone turns on normally, sounds, vibrates and the charging LED works. Do you think it is this broken ribbon, which in my opinion does not matter for the operation of the display, is the cause or maybe something else?
    best regards
    • Sony Xperia Z2 (D6503) Display Non-Functional Post-Replacement: Could a Broken Ribbon be the Cause? 1.jpg (340.17 KB) You must be logged in to download this attachment.
  • #2 16336252
    plustek
    Help: 176
    Rate: 200
    Replace the fuse.
  • #3 16336284
    Loginovsky
    So this broken ribbon has no meaning for the operation of the display?
  • #4 16337122
    bogdan2491
    Help: 52
    Rate: 96
    As for the ribbon that you put in the photo, it is crucial for the operation of the display - after all, it connects the display with the motherboard, if the paths from the display are broken, then it's like you wouldn't connect it at all.
    RAFAŁ.M
    Level 19  
    Help: 21
    Rate: 61
    The broken tape is from the polyphony speaker. At most there will be no bells. Check if something is visible on the LCD when illuminated by the lamp. It is possible that the LCD is working and does not illuminate the fuse for replacement as plustek wrote.
  • #6 16339653
    bogdan2491
    Help: 52
    Rate: 96
    Indeed, I didn't notice the marked break point.
  • #7 16341953
    Loginovsky
    After the backlight, nothing can be seen. I have no idea what's wrong. I gave the phone to the service because I didn't want to play with it any longer, we'll see what they say.
  • #8 16373531
    pawelhd2003
    Rate: 23
    Write back when you get a diagnosis for a learning purpose for us.
    However, I think that it is this fuse, I had the same problem recently.
  • #9 16379688
    maku151
    Help: 17
    Rate: 34
    New replacement ribbons do not work at z1.
  • #10 16381524
    Loginovsky
    The problem was bad insulation of some tape, so if someone is playing with such replacements, I recommend checking the correct insulation. The fuse itself was ok.
✨ The discussion revolves around a user experiencing a non-functional display on their Sony Xperia Z2 (D6503) after a replacement. The user suspects that a broken ribbon cable, which connects the display to the motherboard, may be the cause of the issue. Responses indicate that the broken ribbon is indeed critical for display operation, as it affects connectivity. Some participants suggest checking the LCD for visibility when illuminated and consider the possibility of a blown fuse. The user ultimately decided to take the phone to a service center for further diagnosis, noting that previous experiences with insulation issues in ribbon cables could also be relevant.
