Xbox 360: Disc Cannot Be Read Error - Troubleshooting FIFA 17, FIFA 18 & PES 12 Issues
maciekmens 8322 3
  • Likely failing Xbox 360 laser or disc drive
    #1 16822719
    maciekmens
    Hello. I have had the xbox 360 console for 10 months. Until now, it worked without any complaints, but as always, something must break. I will add that I only play in fife 17. The case is that when I start playing after an indefinite time (once it is after a minute of play, once after five), it crashes the error I hate in the attachment and in the title. I don't think I have to say that I tried wiping or even polishing this plate and nothing else. When buying an xbox, the 12 pes game was included and, surprisingly, this error does not pop up there. Convinced of the guilt of this "broken record" I bought fife 18. So what? And then the same, the same error all the time. I formatted the disk but it didn't help. I do not know if this is an important detail, but when this message is to appear moments earlier (2-5 seconds), the drive slows down and it seems to stop working. Convinced of his helplessness, he directs his help here and I hope that someone will help me.
    • Xbox 360: Disc Cannot Be Read Error - Troubleshooting FIFA 17, FIFA 18 & PES 12 Issues IMG_20171114_154115.jpg (1.72 MB) You must be logged in to download this attachment.
  • #2 16857838
    maffxx
    Rate: 17
    Looks like a broken laser. Do you have any other CDs to check it out?
  • #3 17008102
    Xuadzilla
    If you read from a disc, it means that you have a damaged laser, and if you read from a USB stick, it means that you have a damaged USB port
  • #4 17008858
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    After all, he wrote that he bought FIFA18. Didn't write a new one.
    I put it as my friends wrote for a damaged drive, specifically a dirty / worn laser.
