Xbox 360 FAT 2008: Replacing Benq Motor & Troubleshooting Philips & Lite-On Drive Eject Issues
cinek2107 10143 6
  • Eject motor voltage and tray limit switch behavior
    #1 16337785
    cinek2107
    Help: 24
    Rate: 21
    I warmly welcome. I have a problem. Recently, a friend gave me an Xbox 360 Fat version. Year of production 2008. The console was running normally until one day the drive started to go crazy. Sometimes an attempt to eject with the button gave nothing and you had to click several times and similarly with closing.
    I got it and decided to run it, the more so because I have one at home with a damaged drive.
    Initially I wanted to swap drives and make a spoof but found it better for me to see inside.
    I dismantled the drive, no dust, no dirt etc. I came to the conclusion that I will try to replace the motor with the tray eject.
    So I desoldered a working Benq motor from my drive and soldered it to the drive from my friend's console. The drive that sits here is Philips & Lite on.
    Tries to see what's going on and nothing. I did not put the belt on the engine wheel to see if the engine was running. By pressing the button, the console signals Opening and pressing Closing again, but the engine is stationary.
    Closing or opening is all the time, i.e. if I press eject, the opening is endless. I found that I would eject the tray by hand all the way and then the console should see that the drive is open, but it doesn't.
    Please give me some suggestions:
    - I can check if there is voltage to the motor to check if it is in working order, but please give me what the value should be.
    - what about the opening / closing sensor? It's not that even though I opened the drive manually, it should detect that it is open?
    I don't know if I understand correctly but there are two yes? They remind me a bit of a limit switch. Now the question is whether one signals closing and the other opening? Do they both signify the same? ie if the drive is open, both are short-circuited and when it is closed they are short-circuited?
  • #2 16337822
    sylweksylwina
    Help: 1882
    Rate: 2355
    You have a limit switch, check if it works, it detects if the drive is open or closed. Also check that the drive's power cable is complete.
  • #3 16340999
    cinek2107
    Help: 24
    Rate: 21
    Hello. There are two sensors. One for closing and the other for opening. At least I think so. Both are working, they close the circuits as they should.
    The power cord is also functional. Every vein checked in turn.
    Any other suggestion?
  • #4 16341005
    sylweksylwina
    Help: 1882
    Rate: 2355
    Defective engine controller.
  • #5 16341593
    cinek2107
    Help: 24
    Rate: 21
    I just wanted to add that I was able to fix the problem. I do not know what the thing was, but I dismantled the equipment again, to be sure, I checked the sensors for closing / opening.
    I found that nothing has changed here, but I will try to fire up the console again, this time with the tray pulled out.
    And that turned out to be the key to success. Previously, I always put the drive in with the tray closed and there was no reaction from the motors and the laser.
    After inserting with the open tray, it is hidden and now works as it should.
  • #6 16341638
    sylweksylwina
    Help: 1882
    Rate: 2355
    Maybe cold February at the drive's power connector. Something had to go wrong, there aren't any miracles :)
  • #7 16341944
    cinek2107
    Help: 24
    Rate: 21
    Oh, there is no such thing, but I am glad that it started because the spoof did not want to do, the more so that I would have to translate the laser to Benq.
The discussion revolves around troubleshooting an Xbox 360 Fat (2008) drive, specifically addressing issues with the Philips & Lite-On drive's eject mechanism. The user initially attempted to replace the drive motor with a working Benq motor but faced challenges with the drive's response. Suggestions included checking the limit switches and power connections, which were confirmed functional. Ultimately, the user resolved the issue by inserting the drive with the tray open, which allowed the motors and laser to function correctly, indicating a potential misalignment or connection issue when the tray was closed.
