LG K10 K420N - Display Issues, Backlight On but No Content, Overnight in Cold Car, New LCD
tommy999 4851 2
  • #1 16823791
    tommy999
    Help: 11
    Rate: 80
    I have a problem with the LG model K420N phone.
    I left him overnight in the car (it was 5 degrees outside) In the morning when I wanted to call I saw that he was turned off. I turned it on and it started up but the screen was black ...
    In general, the phone turns on, you can call it but does not display anything (i.e. no content because the backlight is on). I disassembled the phone inside, you can not see traces of patina moisture, etc. My diagnosis fell on the damaged display since everything else works and the lcd connector looks nice, to be sure I cleaned it. I bought a second new one on Allegro. Today came the connected and still the same symptom. The backlight turns on but there is no content on the display.
    Please help
  • #2 16858028
    Orzel27
    Help: 91
    Rate: 52
    Hello. Is the phone falling after falling? Defects caused in this way may manifest themselves after some time. The new LCD may also be out of order, such a small coincidence.
  • #3 16930921
    tommy999
    Help: 11
    Rate: 80
    It was enough to heat the disc well and it works
