Nokia 5: Photo & App Storage Location, Phone & SD Memory - Settings Activation Guide
Włodzimierz Balcerek 7932 7
  • #1 16835029
    | please specify how to activate the phone's "settings", where to save photos or "downloaded" applications. In the phone memory or SD memory
  • #2 16835377
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Let's set one up. Do you mean photos or applications ??
  • #3 16835475
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    To change the image storage location, activate the camera function, then touch the 3 horizontal lines to locate the data storage item and change to the SD card. Applications downloaded for installation through the Google Play Store are saved in internal memory and this will not change, other programs such as mini opera allow you to change the location of downloaded files.
  • #4 16835772
    Thanks for fast reaction. But unfortunately this field exists but is inactive! Can there be something in the program?
  • #5 16835826
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    To be able to change the storage location for photos and videos, you must first have a memory card inserted in the phone's memory slot.
  • #6 16836172
    The card is inserted, even there are files stored on it, there are several photos, and "docx" files that can be read on the phone. It seems to me that when I bought this phone, the function of choosing the place of saving was active and the files that were saved on this card by me in this location.
  • #7 16837098
    bogdan2491
    Help: 52
    Rate: 97
    As for photos and videos, you can definitely change the save location in the camera's application settings.
  • #8 16838718
    Thank you for your help. Your suggestions forced me to further analyze the reasons. After removing the SD and re-inserting it into the socket, a message appeared on the screen about the need to format it (with the simultaneous loss of files stored on it). After formatting, the "save location" was activated and I could choose "save photos to SD memory card" I consider the topic finished.
The discussion focuses on how to activate the settings for photo and app storage locations on the Nokia 5. Users inquire about changing the default storage from internal memory to an SD card. It is clarified that to change the image storage location, the camera function must be activated, and the SD card must be inserted. Initially, the option to change the storage location may be inactive, but after reformatting the SD card, users can successfully select it as the storage destination for photos. Applications downloaded from the Google Play Store are saved in internal memory by default, although some third-party apps may allow changing the download location.
