Samsung Galaxy J5 (J500FN) - Moving Apps to SD on Android 6.0.1, Formatting Issues & Solutions
CMK1990 10857 3
  • #1 16947185
    CMK1990
    Help: 13
    Rate: 119
    Hello. I got to the "fun" Samsung galaxy J5 exactly model j500fn. He received the official android 6.0.1.
    The whole problem with this phone is that after installation of system updates, there is literally 1gb of internal memory space for applications. With today's facebooks, messengers and instagramach is definitely not enough.
    Android 6.0 should "propose" the format of a newly inserted blank card as internal or mass memory. To my surprise, this unfortunately does not offer option No. 1. It proposes only the format as mass memory - why?
    * I even tried with a non-stock ROM, and the same does not have the card format option.
    * In addition, I tried the Link2SD application and the ext2, ext3 and ext4 partitions. In the case of ext2 like it moves, while the application moved to SD does not start and after reboot disappears. So, no sense.
    Has anyone processed this problem and can help? Because I'm slowly lacking strength for this phone.
  • #2 16947247
    leonov
    Help: 1039
    Rate: 2247
    Root is it?
  • #3 16947344
    CMK1990
    Help: 13
    Rate: 119
    Of course, the root bootloader is everything. Rights granted for link2sd
    dgolf
    Help: 11
    Rate: 151
    For me, Apps2SD worked in the Pro version bought for about 10 PLN. Link2SD oil. I created partitions from the application level. However, the speed of action did not even knock on quick cards. For this, you can go down with a ROM occupancy of up to 55%. I recommend, however, a different solution.
    I recommend this ROM https://forum.xda-developers.com/showpost.php?p=73970046&postcount=260 plus the Open Gaaps pico version. Bluetooth works, camera with video recording. The memory after installing and installing the messenger - 3.41 occupied from 7.28.
    If, however, stock, then only 5.1 - six are not able to download all updates, because there is no ROM. Marketing treatment.
