[Solved] Xiaomi Redmi 5: Computer Not Detecting SD Card - Settings, Debugging & Solutions for Access
bogdan008 8595 3
  • #1 17389973
    bogdan008
    Rate: 30
    Please let me know how to change the settings in the phone so that the computer can see the SD card.
    I've checked debugging and still can't see the SD card. When removed from the phone and inserted into the computer, the card works.
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    After connecting the phone to the computer, expand the notification bar and select the type of connection files (MTP) otherwise the phone will charge the battery, connection of the phone to the computer is described in the user manual, section USB connectivity, page 10.
  • #3 17397440
    131XIII
    Rate: 48
    Alternatively, disable usb debugging in the settings
  • #4 17712501
    bogdan008
    Rate: 30
    Problem solved. Just drag the bar from the top of the phone and select USB options.
