[Solved] PC / Win10 - Post-Game Installation Issue: Black Screen with CMD Console at Startup
Jarek Bachanek 15240 1
  • #1 17321703
    Jarek Bachanek
    Rate: 34
    I have a problem that probably results from installing a platformer. Although the game did not install (an error occurred at the end of the installation), but I installed it on another computer and after restarting the system there appeared an identical problem.
    And it relates to the fact that after logging in to Windows, a black screen appears with a small console window cmd with the command C: \ Windows \ System32 When you type the command explorer or explorer.exe only then the desktop and everything else starts. Then the system works normally. How to make the screen and console not appear? I attach logs from FIRST and Addition.txt
    edit:
    I solved the problem using the post of the user who managed it.
    • Addition.txt (45 KB) You must be logged in to download this attachment.
    • FRST.txt (75.11 KB) You must be logged in to download this attachment.
  • #2 17321750
    Jarek Bachanek
    Rate: 34
    I solved the problem using the post of the user who managed it:
    "1. Open Notebook and paste in it:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon]
    "Userinit" = -
    "Userinit" = "C: \\ WINDOWS \\ \\ system32 Userinit.exe"
    [HKEY_CURRENT_USER \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon]
    "Shell" = -
    From the Notebook menu> File> Save as> Set extension to All Files> Save as FIX.REG> from the right-click, select Merge
    2. Reset the system "
    I did so and the problem disappeared.
