Toyota Avensis T25 (2004) 2.0 Diesel - Locating Low Beam Fuses for Left & Right Lamps
d2mac 31809 4
  • #1 16837170
    d2mac
    Rate: 21
    I have a car like in the topic, 2.0 diesel, vintage 2004.
    I can not find the fuseheads from the dipped beam for this model before the lift.
    After the lifter I found, but the fuse distribution does not match.
    Could someone indicate the fuses from the low beam, the left lamp, the right lamp.
    Thank you
  • #2 16837365
    Doktorr
    Help: 287
    Rate: 1098
    Check the box in the engine compartment above the radiator.
  • #3 16837523
    d2mac
    Rate: 21
    That's right. Thank you for the hint.
    I also do not have lamp adjustment. The motors from the lamps do not regulate. The fuse is responsible for this.
  • #4 16838748
    Doktorr
    Help: 287
    Rate: 1098
    In cabin no. 39, 7.5A together with the reversing light. (left row 5 socket from the bottom)
  • #5 16841373
    d2mac
    Rate: 21
    Yes it was this fuse.
    Thank you. I close the subject
