Should my Toyota Yaris 1.3 VVTi have the 20A FR DEF fuse in the engine-compartment fuse box if the manual says "without circuit"?
No — that fuse position is for Yaris versions with a heated windshield/defogger, so if your manual says "without circuit," your car likely does not use it [#17140882] For the radio and cigarette lighter fault mentioned later, the fuse box is in the cabin under the steering wheel, behind the small flap above the pedals [#17141974][#17142065][#17142291] Another reply notes that different cabin fuse-box versions existed on the Yaris Mk2, so the exact layout can vary [#17140916]
The flap should be opened. Look with the flashlight above the pedals, it should be seen. I haven't had this car for a long time. The radio has stopped playing overnight?
The discussion revolves around the fuse configuration in the engine compartment of a Toyota Yaris II 1.3 VVTi. The user inquires about the presence of a fuse labeled "FR DEF 20A" which is noted as "without circuit" in the manual. Responses indicate that this fuse may not be necessary if the vehicle lacks a heated windscreen. The user also seeks assistance in locating the cabin fuses after experiencing issues with the radio and lighter, which have stopped functioning. Suggestions include checking under the steering wheel and using a flashlight to locate the fuse box above the pedals. AI summary based on the discussion. May contain errors.
