Toyota Avensis - Electric brake (automatic) Avensis 2009 (46300-05010)
111lisu 34965 13
How can I clear C1203 and adapt a used Toyota Avensis electric parking brake actuator after replacement?
You generally cannot adapt a used EPB actuator in this Avensis; Toyota’s procedure expects a new module, with manual programming/adaptation and matching vehicle specification, and used units are reported not to work [#15176783][#15179469] The replacement actuator must match the car exactly, including LHD/RHD and AT/MT, otherwise the system will complain about a vehicle information mismatch [#15149855][#15177804] One reply says the service procedure is to flash the module and add the VIN, but only for the proper matching unit, not a mixed-spec used one [#15165675] After fitting a correct, operational actuator, point 0 calibration and erasing old data should be done only when the new actuator is working properly [#15149520] Several posters concluded that forcing the old unit via EEPROM/VIN editing was unsuccessful and that the 1203 fault remained [#15179469]
  • C1203 mismatch after replacing Avensis parking brake ECU
    #1 15149215
    111lisu
    Rate: 52
    I have such a question
    The electric brake in Avensis 2009 has been damaged
    In these models it is supposedly a norm.
    http://www.surreyelectronics.com/leaflets/TOY...S%20ELECTRONIC%20PARKING%20BRAKE%20SYSTEM.pdf
    To my surprise, flooded like the one above, dismantling this crap is also fun; (
    However, after the exchange, which was supposed to be a formality, it does not go to put out mistakes
    http://intranet.toyotaperu.com.pe/tdp_sit/dat...0e/repair2/html/contents/rm000002tzo008x.html
    C1201 / 64
    Engine Control System Malfunction
    - Engine control system
    - Electric parking brake ECU (Parking brake with bracket actuator assembly)
    C1203 / 73
    Vehicle Information Mismatch
    - ECM
    - Main Body ECU (Instrument panel junction block assembly)
    I did not erase the errors in the engine at the very beginning.
    And so I wonder if this 1203 will die now when the car will arrive.
    I have no idea what to do or I do not know if I can do it
    Despite the same number on the controller.
    The driver is eep 95160 and I'm thinking about batching
    in the case of "W" but I do not like to stick to it because it is a very stubborn cattle.
    There is some SMD bone for this but it's hardcore
    By the way, the water gets through the cable at the top
    A seal like that splashes around her.
    Service says it's 1h robots ;)
    Maybe somebody had some better experiences with this crap.
    I do not want to undress it again. I do not do this with CDIF
    and Delphi can not handle it at all, it can not even drive
    do I delete errors and do not have any other tools for this.
  • #2 15149520
    antonilukka
    Rate: 17
    Point 0 calibration, erasing old data
    only when the new engine is operational
  • #3 15149855
    deesz
    Help: 25
    Rate: 205
    You can not mix these cylinders. How the car is LHD is with LHD, as RHD is with RHD, as AT is with AT, as MT is with MT.
  • #4 15149939
    antonilukka
    Rate: 17
    And I do not know, but the machine and manual probably do not
    But do they differ from which they have a steering wheel, probably not
    the procedure differs only if the engine 1ww or 2 above
  • #5 15151765
    deesz
    Help: 25
    Rate: 205
    Car from 2009. There was then 1WW, 2WW.
    Among other things, after connecting a new actuator, the following data is added:
    • Toyota Avensis - Electric brake (automatic) Avensis 2009 (46300-05010) epb.JPG (15.96 KB) You must be logged in to download this attachment.
  • #6 15154732
    111lisu
    Rate: 52
    antonilukka wrote:
    Calibration point 0 delete old data
    OK, what to enter?
    The label on the cheese maker is the same as in the original one.
    The engine is used and works, draws and lets go.
    I tried CDIF and did not like to change anything.
    And Delphi does not even test the driver.
  • #7 15165675
    111lisu
    Rate: 52
    The VIN will be the same as the new driver, but you still need to adapt,
    how the old service must do a flash and add a VIN and how we will see.
  • Used EPB module reportedly cannot be adapted to Avensis system
    #8 15176783
    111lisu
    Rate: 52
    No serwis sobie nie poradził :(
    Znalazłem takie info:
    http://mhhauto.com/Thread-Toyota-Avensis-T27-parking-brake-problem
    Hi I have a problem to adapt used electric parking brake in Avensis 2011 year.
    I have a trouble code P1203 - Invalid Data. I attached dump 95160 from EPB. Did anyone know it is possible to clear this fault code ? I think
    I need to change VIN but I can't see VIN in eeprom dump.
    hi. The manufacturer does not provide for the installation of the module used . .Vin Does not occur.
    There is a match the other ECU.
    You can install a new module and program (there is only manual matching method module) only.
    To wiele wyjaśnia ;) Czyli jednorazówka - brawo dla Toyoty.
    I takie też wynalazłem:
    http://www.digital-kaos.co.uk/forums/showthre...5361-Toyota-Avensis-T27-parking-brake-problem
    Macie jakiś pomysł?
    Bo inaczej to chyba tylko 95160
  • #9 15176881
    deesz
    Help: 25
    Rate: 205
    I wrote a problem and you lose time and money.
  • Brake operates normally despite two warning lights remaining
    #10 15176986
    111lisu
    Rate: 52
    Among other things, after connecting the new actuator, the following data is added:
    Yes, you wrote it, but it's about the new driver, at least that's how I understand it.
    And the same writes in the link that I posted, and the substance is currently being formed,
    with the same numbers, not repaired, unsealed,
    which the manufacturer did not anticipate for obvious reasons (almost 3k).
    The brake works, it picks and releases from the switch, only displays two lights in the meter and that's the whole problem.
    If I misunderstood you, please improve.
  • #11 15177804
    deesz
    Help: 25
    Rate: 205
    It can be used, it will work immediately after connecting, the lights will go out but it must be from a car with the same specification: AT, MT, LHD, RHD.
  • Used brake module cannot be reprogrammed successfully
    #12 15179469
    111lisu
    Rate: 52
    Well, unfortunately, it will not work. as mentioned by experts from the links above.
    Because it is a used part, it's strange that the website did not know about it.
    Reprogramming / soldering EEP 95160 errors went wrong ;)
    The full release of CDIF and all 1203 is also history.
    Probably the VIN is coded, because it can not be seen in the dump with the naked eye
    But putting this wonder apart is a nightmare.
  • #13 15179918
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    Those good from the service went abroad, orphans, or lovers.
  • #14 15180969
    111lisu
    Rate: 52
    Well, what's up, maybe it's not that bad.
    Only a pity was the time and the way to them.
The discussion revolves around issues with the electric parking brake in a 2009 Toyota Avensis, specifically concerning error codes C1201 and C1203 after replacing the actuator. Users highlight the importance of proper calibration and the need to adapt the new actuator to the vehicle's specifications, including VIN matching. There are mentions of difficulties in erasing fault codes and the necessity of using compatible parts from vehicles with the same configuration (LHD/RHD, AT/MT). The conversation also touches on the challenges of reprogramming used parts and the limitations of available diagnostic tools.
