BMW E60 3.0 TDI Losing Power, Revs Max 3000 RPM, Top Speed 140, No Smoke - Gearbox & Noise Issues
lukas92p 9636 5
  • #1 16843308
    lukas92p
    Rate: 27
    Hello dad has a bmw e60 3.0tdi and the car has no power. He doesn't screw at revs at 3000rpm max and the speed reaches 140, he doesn't want to go. I will add that the box changes gears well, there is no smoke under the bonnet. What could it be? no disturbing noises from under the bonnet are gone
  • #2 16843312
    Cobrat
    Help: 35
    Rate: 501
    First of all, diagnostics, not divination ... You can repair the lack of power for a dozen or several dozen / several hundred zlotys ... Think about whether you want to buy everything in turn, which they will start offering you ...
  • #3 16843320
    lukas92p
    Rate: 27
    Ok, it will do so. As I know I will write more
  • #4 16845407
    lukas92p
    Rate: 27
    The computer showed up
    Particulate filter and candle sensor and candles do not work evenly after firing, is it related to power loss?
  • #5 16845553
    andrzej20001
    Help: 1578
    Rate: 6669
    It certainly has a relationship, the car needs to be repaired by a diesel specialist.
    typer
    Rate: 36
    A damaged glow plug driver and / or damaged glow plugs affect difficult firing and uneven operation a few seconds after firing. The colder it will be, the harder it will be to start the car.
    A clogged diesel particulate filter (DPF) causes a loss of power, in the final stage the engine will start but will not have the strength to drive and then will not even start. At BMW, everything has to be operational so that the DPF is burned out while driving. For example, a faulty thermostat (main or EGR cooler) will not show an error in the computer and the DPF will not burn (because the coolant will not reach 75 degrees).
