BMW E46 320d 150km - Black Smoke During Acceleration, Power Loss, Flow Meter Issues
BartekBMW231 17838 12
Why does my BMW E46 320d smoke black and lose power under acceleration, but run normally when the MAF sensor is disconnected?
The black smoke and power loss are more likely caused by a leaking EGR system or a cracked air/boost hose than by the MAF sensor itself [#17468185] [#17467503] [#17469136] Disconnecting the MAF can make the EGR stop working, which can temporarily hide the fault and bring power back [#17468185] [#17469362] Check the hose between the turbo and manifold, the intercooler, and especially the cracked rubber hose from the EGR to the intercooler pipe [#17467503] [#17470311] One reply also suggested the MAF should be tested by swapping it from another car, but the final clue from the thread was a badly cracked hose and a sticky EGR [#17469245] [#17470311] Replace the damaged hose anyway, even if it is not the only fault [#17471362]
  • #1 17467162
    BartekBMW231
    Hello, I could not find a similar topic, namely that in my BMW E46 320d 150km 380,000 mileage I have a small problem, the car started to kick black during acceleration, I note that the injectors are within the turbo standard after regeneration in July this year. I gave the car to the electrician, he checked more or less the car on the computer, including the flow meter that showed the correct parameters, theoretically, there is nothing to attach to, but after disconnecting it, the power returns and stops mounds, for now I go disconnected but for too long it is probably not too smart and my question is before it gets into the cost of making the original new flowmeter, is there any other option to smoke and run out of power? If, after unfastening the car, it works perfectly, i.e. it has no smoke, then the fault is 100% in the damaged flow meter, although it does not show any irregularities under the computer. greetings
  • #2 17467503
    paszczakq
    Help: 48
    Rate: 204
    The hole between the turbo and the manifold? Blew the intercooler. Maybe the hose cracked.
  • #3 17467918
    marfur30
    Help: 138
    Rate: 386
    Try to flush this flow meter with gasoline.
    These parameters were read while driving or at a standstill ??
  • #4 17468114
    BartekBMW231
    Hey, I honestly don't know what the electrician meant when he said that according to the computer, the flow meter is the case. I just wonder why after disconnecting the ankle everything stops and the car works properly and the mussels and smoke are connected or is it 100% of the flow fault.
  • #5 17468185
    żałosna udręka
    Help: 191
    Rate: 1020
    You have a damaged EGR. With the flow meter disconnected, it is turned off.
  • #6 17468348
    BartekBMW231
    From what the mechanic said when pressing the gas at a standstill at the EGR, smoke is coming out somewhere so I remembered.
  • #7 17469136
    icosie
    Help: 298
    Rate: 239
    In this case, a leaky EGR or any pipe next to ...
  • #8 17469245
    BartekBMW231
    Thank you very much for the advice, I got the flow meter from the car in which nothing is happening, the same engine, I am now taking the transfer and I will make 100% sure if it is not the fault of the flow, if not, I connect my flow meter and look for the EGR fault. Greetings and let me know what came out of it
  • #9 17469362
    marfur30
    Help: 138
    Rate: 386
    In my opinion, a damaged EGR may not be closed, which causes a loss of power, or closed, which has an impact on the ecology but not on power.
    Removing the flow in such a case should not bring any improvement.
  • #10 17469480
    BartekBMW231
    The flow meter is postponed and the ass on the new car has lost a little less smoke on what was in the car since I bought it, after disconnecting the new one, the power returned, and the light bubble will go but the diesel is no wonder. Have any ideas ? Could a damaged EGR valve come into play here?
  • #11 17469515
    marfur30
    Help: 138
    Rate: 386
    As indicated by the economizer in 4-5th gear with the shoe in the floor?
  • #12 17470311
    BartekBMW231
    Gentlemen, the EGR was hung, I cleaned it nicely, and on the old flow meter the power came back really kicking, which I noticed a stuck rubber hose that goes from the EGR to the intercooler pipe. It looks and is terrible with cracks, etc. is there a possibility that black smoke is caused by this hose?
  • #13 17471362
    żałosna udręka
    Help: 191
    Rate: 1020
    Even if it is not the fault of the nose, replace it anyway.
The discussion revolves around a BMW E46 320d experiencing black smoke during acceleration and power loss, attributed to potential issues with the flow meter and EGR system. The user reports that disconnecting the flow meter temporarily resolves the smoke and power issues, leading to speculation about the flow meter's functionality despite normal readings on diagnostics. Suggestions include checking for leaks in the EGR system and associated hoses, as well as cleaning or replacing the flow meter. The user ultimately identifies a cracked hose connected to the EGR as a possible cause of the black smoke, indicating that both the EGR and flow meter should be examined for faults.
TL;DR: 380,000 km E46 320d showed black smoke and power loss; "With the flow meter disconnected, it is turned off." Root causes: stuck EGR or boost/IC hose leaks; MAF data may look “normal.” Swap-test MAF, clean EGR, replace cracked hoses first. [Elektroda, żałosna udręka, post #17468185]
Why it matters: This helps BMW E46 320d owners fix black smoke and power loss without wasting money on an unnecessary MAF.
Why does my BMW E46 320d blow black smoke under acceleration and lose power?
Black smoke under load means too little air for the injected fuel. Likely causes are boost leaks, a leaky EGR, or split hoses near the EGR and intercooler. A stuck-open EGR reduces oxygen and kills power. Leaks after the turbo waste boost and spread soot. Inspect the EGR and nearby pipes first, then replace torn couplers. Road-test to confirm the fix. [Elektroda, icosie, post #17469136]
Does unplugging the MAF (flow meter) disable EGR on the E46 320d?
Yes. Unplugging the MAF triggers a fallback that turns EGR off and can restore power. As one expert put it, "With the flow meter disconnected, it is turned off." If unplugging reduces smoke and improves pull, suspect EGR or intake leaks before the MAF. Reconnect after diagnosis. [Elektroda, żałosna udręka, post #17468185]
My scan shows the MAF within range; could it still be bad?
Yes. Idle or stationary checks can look fine while the sensor misbehaves under load. Record live airflow and boost during a road test. Compare values with a known-good sensor when possible. If unplugging improves drivability, prioritize EGR and leak checks before buying a MAF. [Elektroda, marfur30, post #17467918]
Could a cracked hose cause black smoke? Which hose should I inspect first?
Yes. Cracked intercooler plumbing will drop boost and push soot out. Start at the rubber hose between the EGR and the intercooler pipe. Look for oil mist, splits, and soft spots. Replace any suspect hose and retest under load. This fix has resolved both smoke and power loss. [Elektroda, BartekBMW231, post #17470311]
I cleaned the EGR and power improved; what should I do next?
Reconnect the MAF, then inspect and replace any cracked couplers near the EGR and intercooler. Perform a WOT road test to confirm stable power and reduced smoke. If symptoms return, recheck for leaks and EGR operation. The combination of EGR cleaning and hose replacement often solves it. [Elektroda, BartekBMW231, post #17470311]
How do I quickly check for boost leaks between turbo, intercooler, and manifold?
Do this quick check:
  1. Inspect all charge hoses and the intercooler for oil mist, soot, and splits.
  2. Check the EGR elbow and clamps; look for soft or cracked rubber.
  3. Repair or replace any suspect part, then WOT test to verify. These spots commonly crack and dump boost. [Elektroda, paszczakq, post #17467503]
Is it safe to drive with the MAF unplugged?
Use it only as a diagnostic or limp-home measure. Unplugging disables EGR and may mask issues. Long-term driving this way is unwise and can affect emissions. Fix the root cause, then reconnect the MAF for proper control. The owner noted it’s not smart to run unplugged for long. [Elektroda, BartekBMW231, post #17467162]
How can I tell if the EGR is the culprit versus the MAF?
If unplugging the MAF stops smoke and restores power, suspect EGR or leaks first. The unplug test turns EGR off, so improvement points at EGR flow or sealing. After cleaning or fixing leaks, reconnect the MAF and retest. Persistent faults may then warrant MAF evaluation. [Elektroda, żałosna udręka, post #17468185]
Smoke is visible around the EGR when revving. What does that indicate?
Smoke near the EGR suggests a leaky EGR valve, gasket, or adjacent pipe. The leak vents exhaust or soot and reduces effective boost. Fix sealing and any split hoses, then road-test. Expect reduced smoke and better throttle response after sealing the system. [Elektroda, icosie, post #17469136]
What gear and load should I use for road-testing this issue?
Use 4th or 5th gear with the accelerator to the floor on a safe road. Watch the economizer or response for signs of underboost. This stresses the system and exposes leaks or EGR sticking. Log data during the pull for clear comparisons. [Elektroda, marfur30, post #17469515]
Should I clean the MAF, and how do I validate the result?
You can try cleaning the MAF, then verify by logging live airflow while driving. Compare behavior before and after cleaning. If data remains unchanged and unplugging still helps, focus on EGR and charge-air leaks. Always test under load, not only at idle. [Elektroda, marfur30, post #17467918]
Does a stuck-closed EGR reduce power on this engine?
A closed EGR primarily affects emissions, not power. A stuck-open EGR, however, will reduce power and increase smoke. Prioritize diagnosing an EGR that fails to close under load. “Closed EGR impacts ecology, not power.” Repair EGR function and retest. [Elektroda, marfur30, post #17469362]
Injectors and turbo were refurbished. What should I check next?
Focus on the air path. This 150 KM car reported issues at 380,000 km after injector and turbo service. Inspect the EGR for sticking and check all intercooler hoses. Unplug test results can guide you toward EGR or leaks rather than fueling. [Elektroda, BartekBMW231, post #17467162]
I swapped in a known-good MAF but still have smoke. What now?
If a good MAF changes little and unplugging it restores power, shift attention to EGR and hoses. Clean a sticking EGR and replace any split couplers. Then reconnect the MAF and road-test under load. This sequence often resolves smoke and power loss. [Elektroda, BartekBMW231, post #17469480]
