Navitel F150 Unlocking 100% Test: Replacing Navitel Folder - Tested & Successful!
markosmal1 9357 3
  • #1 16844476
    markosmal1
    Rate: 24
    We replace the Navitel folder tested :D .
    • odblokowanie navitel f150.rar (17.35 MB) You must be logged in to download this attachment.
  • #2 17206234
    kev21
    Rate: 27
    Unfortunately, it does not work correctly, it is certainly not prepared for this model, the system works with 800x480 screens and the F150 model mentioned in the subject has 480x272 and is unusable on this device .. pity
  • #3 17206443
    jajacekpl
    Help: 65
    Rate: 268
    In this model, the navite / navite.exe file is always run from the internal memory.
    So take any panel for your resolution, the original Navitel folder, rename, for example, Navitel_ a folder with panel and an exe file, change as above
    And in the first post is the panel frixi, to which - I have the impression - a colleague markosmal1 does not have any proprietary / copyright (see http://www.frixi.pl/)
  • #4 17212305
    kev21
    Rate: 27
    Well, only I have no idea what to use :-) do you have something checked? [/ u]
