How to Launch Automap from SD Card on Navitel E700 Navigation System?
senior38 27147 7
  • #1 16458066
    senior38
    Rate: 10
    Navigation Navitel E700 navitel maps are installed, but I have an automap on the sd card and how to start it.
  • #2 16459137
    jajacekpl
    Help: 65
    Rate: 268
    Two options:
    1. Copy the program to the device (leave the map to the SD), rename it to Navitel and the file Automapa EU.exe to Navitel.exe
    2. Overwrite the navitel.exe file with a script redirecting to the Automapa EU.exe file on the card
  • #3 16488534
    senior38
    Rate: 10
    Thank you very much for the information, but this way I can not run the automap from the sd card. I have one more question and how to format the main navigation memory and install a free NavRoad map and run from the Automapa card. I have heard about this method, but I'm afraid of losing Navitel's map . Maybe someone tried this way, please let me know.
  • #4 16488544
    jajacekpl
    Help: 65
    Rate: 268
    Do not format the memory, because the device will be suitable only for the smoker
    Turn on displaying file extensions and check if you changed the name to Navitel.exe or navitel.exe.exe
  • #5 16489394
    senior38
    Rate: 10
    And how to enable this extension? A name on the card changed to navitel exe.
  • #7 16497835
    senior38
    Rate: 10
    In spite of everything, nothing comes out. I am staying at Navitel and thank you for your help. greetings
  • #8 16499072
    japycz321
    Help: 92
    Rate: 141
    You can. The AutoMapa.exe file searches for the wceAM.exe file and launches it. If the entire map will be on the memory card, it will start from it to you.
✨ The discussion revolves around launching AutoMapa from an SD card on the Navitel E700 navigation system. Users suggest two main methods: copying the AutoMapa program to the device and renaming it to Navitel.exe, or creating a script to redirect the original Navitel.exe to the AutoMapa executable on the SD card. There are concerns about formatting the device's memory, with advice against it to avoid losing existing maps. Users also discuss enabling file extensions to ensure correct file naming. Despite attempts, one user reports difficulties in successfully launching AutoMapa.
