Navitel E100 Unlocking Panel Issue: Uploading for New Maps, White Screen Problem & Solutions
tino2003 7086 7
  • #1 16788910
    tino2003
    Admin of GSM Group
    Help: 1972
    Rate: 2087
    I want to upload the unlocking panel on the Navitel E100 to be able to choose other maps than the factory ones.
    I change the name of the original Navitel folder, upload files with the panel, navigation starts with a white screen every time.
    I have already uploaded these prefabs from 5 different ones and the same on each one.
    Where am I making a mistake?
  • #2 16789014
    jajacekpl
    Help: 65
    Rate: 268
    And the specifics? What folder and EXE file name from the panel?
    The most common error is the wrong file name extension.
    Should:
    ResidentFlash \ Navitel \ NAVITEL.exe
  • #3 16789033
    tino2003
    Admin of GSM Group
    Help: 1972
    Rate: 2087
    I change the factory Navitel folder to Navitel1 and give the one with the Navitel panel.
    • Navitel.rar (4.6 MB) You must be logged in to download this attachment.
  • #4 16789274
    jajacekpl
    Help: 65
    Rate: 268
    Theoretically it's OK - to be sure, try to run CeCommander this way.
    Maybe they changed something, e.g. it checks the checksum of an EXE file
    To be sure (because I make stupid mistakes myself in the simplest of matters) - you have a structure
    or maybe
    ResidentFlash \ NAVITEL \ NAVITEL \ NAVITEL.exe?
  • #5 17277772
    atmpitbull
    I connected the E100, dumped everything that was on the disk, installed the automapa, changed the folder to navitel and wcmam.exe to navitel.exe and it flashes.
  • #6 19377744
    koniujbie
    I have the same problem as the colleague who founded the topic. I also deleted all the content and uploaded the panel itself and the problem is still the same - white backlit screen. MS700 navigation from wince. I'm running out of ideas, so I am asking for help
  • #7 19436841
    vaczak
    Help: 50
    Rate: 141
    Witam!
    Koniujbie, Ten błąd można naprawić tylko przez aktualizację ROM. Obie wersje WinCe (pojemnościowe, rezystancyjne) mają ROM.
  • #8 19439254
    jajacekpl
    Help: 65
    Rate: 268
    Then I have the same question for you as for him - see the post from Oct 30, 2017 at 13:39
✨ The discussion revolves around issues faced while attempting to upload an unlocking panel on the Navitel E100 device to access additional maps beyond the factory settings. Users report encountering a persistent white screen upon navigation startup after modifying the original Navitel folder and replacing it with the new panel files. Common troubleshooting suggestions include verifying the correct folder structure and executable file name, ensuring it follows the format ResidentFlash Navitel NAVITEL.exe. Some users have attempted to reset the device and reinstall different navigation software, but the issue persists. A suggestion to update the ROM is also mentioned as a potential solution for resolving the white screen problem.
