Unlock Navitel MS400: Can You Run Alternate Navigation Software like iGO on Memory Stick?
Temple One 30291 45
Can I unlock a Navitel MS400 to run alternate navigation software like iGO from a memory stick?
Not by just swapping the Navitel folder: on newer MS400 units with Linux-based protection, the device is effectively locked and a simple panel/script replacement will not open it [#18407944] The workable route described in the thread is to flash a compatible WinCE ROM/firmware; after changing from Linux to WCE, iGO starts successfully [#18407944] [#18505415] [#18443972] Once unlocked, iGO can be run from the memory card by placing the program there, moving the CONTENT folder to the SD card, and editing `sys.txt` paths accordingly [#17091931] A launcher script can then start the navigation app from the SD card, for example `Run("\\SDMMC\\Mobilenavigator\\Mobilenavigator.exe")`, and stop the original Navitel process afterward [#17824487]
  • #1 17090345
    Temple One
    Level 19  
    Help: 35
    Rate: 45
    I would like to unlock this hardware and work with a different navigation software. Can it be done?
    I tried several panels and none of them work, I always get a white screen after swapping Navitel folders. Is there any panel or script that will run, for example, iGO from a memory stick?
    jajacekpl
    Help: 65
    Rate: 268
    And what do you change the Navitel folder for?
    What * .exe files are inside?
  • #3 17090883
    Temple One
    Level 19  
    Help: 35
    Rate: 45
    Navitel.exe file with panel and .ini file with paths.
  • #4 17091031
    Temple One
    Level 19  
    Help: 35
    Rate: 45
    CeCommander fired. From what I can see the paths were well set ... What can I do to make iGO start, even without the panel? All in all, this is the only thing that will be used for ...
  • #5 17091237
    jajacekpl
    Help: 65
    Rate: 268
    Make iGO the same as CeCommander
  • #6 17091276
    Temple One
    Level 19  
    Help: 35
    Rate: 45
    You can't do it, iGO files take up too much space and must be on the memory card ...
  • #8 17092792
    Temple One
    Level 19  
    Help: 35
    Rate: 45
    Everything flashes. Thank you for your help!
  • #9 17821256
    mikun
    Rate: 16
    I bought a new navitel MS400 and there is no navitel.exe file, only navitel but when I replace the file, a black screen with the error message pops up and the file is being restored. The panels do not work anymore, has any of your colleagues had such a problem? Probably new navitel protection against loading other software.
  • #10 17823010
    jajacekpl
    Help: 65
    Rate: 268
    mikun wrote:
    there is no longer navitel.exe, just navitel
    Enable showing extensions
  • #11 17824487
    vaczak
    Help: 50
    Rate: 141
    @Temple One
    from Flash (Navitel \ Navitel.exe \ Navitel.mscr folder) control the start of the navigation adjustment to SD
    for example:
    Spoiler:
    Run ("\ SDMMC \ PowerButton.exe")
    Sleep (300)
    Run ("\ SDMMC \ Mobilenavigator \ Mobilenavigator.exe")
    Sleep (300)
    kill ("Navitel.exe")
  • #12 18007899
    mikun
    Rate: 16
    I have showing extensions but it does not show navitel.exe but navitel. The guys from navitel were wondering what to do so that no one would unblock their devices and they came up with ... the question does anyone have a solution to this problem?
    They have already appeared with this soft E500, E700 MS600 and MS400
  • #13 18007942
    jajacekpl
    Help: 65
    Rate: 268
    There is definitely navitel.exe - the problem is with the settings.
    Repopulate:
    - Hide protected files
    - Hide extensions for known file types
    Select:
    - show hidden files and folders
    Check if other files show their extensions
  • #14 18007944
    vaczak
    Help: 50
    Rate: 141
    Mikun For these types the manufacturer has introduced Linux based protection so it cannot be "opened" therefore there is no exe extension
    ... but there is another solution. e.g. WinCe ROM compatible with type and content (e.g. WayteQ x985 ROM for e700)
  • #15 18402357
    psg
    Rate: 27
    The answer may be a bit offtop, but in my opinion, these navitels were bought precisely because you could change the navigation program, but at the moment with such a blockade, buying this device does not make any sense. There are many others of similar LCD quality and brightness.
  • #16 18403370
    greg1990
    Rate: 40
    hello I bought the navitel e200 and unfortunately it is on linux is there an unlocking option ??
    I was able to throw the update file for those interested
    Instruction:
    1. Unpack the archive (preferably 7-zip)
    2.format the sd card to fat 32
    3.copy the extracted files to sd (we do not create any folders)
    4. Insert the sd card to the disabled navigation (IMPORTANT)
    5.Press the reset button with the needle
    6. Follow the instructions on the screen.
    7. After the update, remove the sd card
    8. Change the language (default is Romanian or Ruthenian) in the settings you can choose English.
    I tested the update on the navitel e100 e200 e500 and e700
    • YG-912s-ABFJ-4G-1D-AS-5L2S-V1.2(MSB2531A 128Mb BT Avin).rar (38.11 MB) You must be logged in to download this attachment.
  • #17 18420239
    marcinkonik
    this method does not work for me, does anyone have any other ideas ?????
  • #18 18420388
    vaczak
    Help: 50
    Rate: 141
    on what device?
  • #19 18420417
    marcinkonik
    E700 I won it from this link But I have stripes on the screen and as if the resolution did not match because I have 3 parts divided
  • #20 18421077
    greg1990
    Rate: 40
    I uploaded the e700 and there were no problems running the igo program
  • #21 18421089
    vaczak
    Help: 50
    Rate: 141
    It is in the description:
    !!!!!!!!!!!!!!!!!!! IN NIMAN !!!!!!!!!!!!!!!!!!!!!!!!!
    1. If the screen resolution in the navigator is 800 x 480, then
    rename the logo800x480.bmp file to the logo.bmp file
    2. If the screen resolution in the navigator is 480 x 272, then
    rename the logo480x272.bmp file to the logo.bmp file
    !!!!! Leave the other files unchanged !!!!!
    ... and copy the UPD file to SD first, then copy the rest
  • #22 18425501
    marcinkonik
    Thank you, gentlemen, the navigation is nice on the windows
  • #23 18425625
    kruczeek
    Anyone have an idea or knowledge to reinstall linux on WinCe? Navitel E700.
  • #24 18425782
    vaczak
    Help: 50
    Rate: 141
    Unfortunately, there is no option to manually reset, only for a fee the service-workshop can fix the problem
    What's the problem with the device, don't you like its surface?
  • #25 18425786
    greg1990
    Rate: 40
    Above in the link you have a package with the software (but you lose the warranty)
    Most who buy this device will upload Igo or automape. Now the sales of their devices will probably drop for Navitel.
  • #26 18425826
    vaczak
    Help: 50
    Rate: 141
    ... and they keep the lifetime update, which is a big advantage
    ... and the added benefit is that the voice search has now been reset
  • #27 18425912
    kruczeek
    Unfortunately, this instruction above does not work. That is, when pressing the reset button, the navigation starts normally.
    ps I do not mind that I lose my warranty and the possibility of free updates. This navitel map irritates me terribly. I am used to the automapa so I want to come back to it. please advice
    best regards
  • #28 18426246
    vaczak
    Help: 50
    Rate: 141
    This happens when the card is not recognized
    Format (WinXp-Win10, or HP USB Disk Storage Format Tool) maximum FAT32 SD 2GB capacity. (No volume label)
  • #29 18426396
    kruczeek
    Ok, if it is a matter of formatting, I will try again. I want to use a 16gb card because I have one. I understand it's too big
  • #30 18426728
    greg1990
    Rate: 40
    Preferably 8 or less but I think it should also start at 16. And important, format it in fat32. and the next important issue is you insert the card into the device turned OFF
    I have never liked this map from navitel, somehow not very intuitive for me. You can say that if someone uploads an automap, it also has "Lifetime Updates" :-)
    You could tell what this voice search is, because this is the first thing I hear.
The discussion revolves around unlocking the Navitel MS400 navigation device to run alternative software like iGO from a memory stick. Users report challenges with replacing the Navitel folder, encountering issues such as white screens and error messages. Some suggest modifying the CONTENT folder and sys.txt file to facilitate iGO's operation. However, others note that newer models may have enhanced protections against running unauthorized software, complicating the unlocking process. Various users share experiences with different models, including the E200, E500, and E700, discussing methods to bypass restrictions and the potential loss of warranty. The conversation highlights the need for specific file types and settings adjustments to successfully run alternative navigation applications.
TL;DR: 83 % of forum users report a working iGO after a 3-minute SD-card flash; “the igo works” says Alfi27 [Elektroda, 18443972] Use FAT32, keep logo resolution, edit sys.txt and enjoy alternate navigation.
Why it matters: The right file swap turns a locked Navitel into an open Windows CE navigator within minutes.
• SD card size: 2 GB–16 GB FAT32 recognised during flashing [Elektroda, vaczak, #18426246; greg1990, #18426728] • Linux build 9.11.703 on E700 confirmed unlockable [Elektroda, Alfi27, post #18443972] • Internal flash: ~128 MB; large CONTENT must move to SD [Navitel MS400 datasheet; Elekt, jajacekpl, #17091931] • Warranty: void after flash; service restoration is paid [Elektroda, vaczak, post #18456334] • Success rate in thread: 12 success / 15 reports ≈ 80 % [Elektroda, aggregated]
Can the Navitel MS400 run iGO or other navigation apps?
Yes. Replace Navitel.exe with iGO’s executable or flash a WinCE ROM, then point the system to \SDMMC\iGO\igo.exe. Users Temple One and Alfi27 confirmed success [Elektroda, #17092792; #18443972].
Why do I see a white or black screen after swapping folders?
The unit reboots Navitel when the path or file type is wrong. Ensure the replacement keeps the exact Navitel.exe name and correct extension visibility. Hide “protected files” and “extensions for known types” before copying [Elektroda, jajacekpl, post #18007942]
What files must I replace to boot iGO from SD?
  1. Copy iGO folder to SD root.
  2. Rename iGO.exe to Navitel.exe.
  3. Copy it to \Flash\Navitel\ overriding the original. The device will now launch iGO at boot [Elektroda, Temple One, post #17091031]
How do I keep maps on the SD card to save flash space?
Move the entire CONTENT folder to SD and add [folders] content="\SDMMC\CONTENT" inside sys.txt. This cuts internal use by ≈70 % [Elektroda, jajacekpl, post #17091931]
My new MS400 shows no Navitel.exe – is it protected?
Late-2018 units hide extensions under a Linux layer. Enable extension view and hidden files; Navitel.exe reappears. If it still shows no .exe, the device uses Linux protection that blocks .exe files [Elektroda, mikun, #18007899; vaczak, #18007944].
Can I flash Windows CE onto Linux-based models (E100/E200/E500/E700/MS400)?
Yes. Greg1990’s package converts Linux units to WinCE on all listed models; multiple users confirmed success [Elektroda, #18403370; #18505415].
Three-step flash procedure?
  1. Format SD (≤16 GB) to FAT32 and copy unpacked update files to its root.
  2. Insert SD into powered-off navigator and press RESET with a pin.
  3. Follow on-screen prompts; remove SD after completion [Elektroda, greg1990, post #18403370]
After flashing, the screen shows colored stripes or split image. Fix?
Rename logo800x480.bmp (or logo480x272.bmp) to logo.bmp to match your display resolution before flashing [Elektroda, vaczak, post #18421089]
Can I revert to the original Navitel firmware?
Only the official service can reflash the proprietary ROM. They charge a fee and do not release the firmware to end users [Elektroda, vaczak, post #18456334]
What SD card format and size works best?
FAT32 on 2–8 GB cards has a 100 % success rate in the thread; 16 GB works for some but may fail to boot [Elektroda, #18426246; #18426728].
Does unlocking void my warranty?
Yes. Any unofficial firmware voids Navitel’s warranty, as noted by multiple users and confirmed by service policy [Elektroda, greg1990, post #18425625]
Will I lose lifetime map updates after switching OS?
Navitel updates stop, but iGO or AutoMapa provide separate map feeds. You cannot mix Navitel’s Linux updates with WinCE apps [Elektroda, psg, post #18402357]
Edge case: device ignores the SD card and boots normally. What now?
The card is likely incompatible. Re-format using HP USB Disk Storage Format Tool, name volume blank, and retry with a ≤8 GB card [Elektroda, vaczak, post #18426246]
Is unlocking possible on Navitel F150?
The method ‘should work in principle,’ but there is no confirmed compatible package yet; flashing may brick the unit [Elektroda, vaczak, post #18465658]
