Fn + print screen does not work - Fn + print screen shortcut in HP Specter does
java3 6630 2
  • #1 16844585
    java3
    Rate: 20
    The Fn + print screen shortcut does not work on the new HP Specter laptop.
    I've often used this shortcut on other laptops for many years and it has never been a problem.
    I have new equipment recently and this shortcut does not work here.
    What could be the reason?
    I will be grateful for help.
  • #2 16845126
    TomekxD
    Help: 62
    Rate: 191
    What would such a shortcut give? Normal print screen takes a screenshot, in Win 10 the Windows key and print screen takes a screenshot to a file. What else can be added here?
  • #3 16845954
    java3
    Rate: 20
    OMG ... You know, the Print screen key itself did not work in all previous laptops - you had to press Fn to take a screenshot. So I got attached to it that it didn't even occur to me to check if Print screen itself was working :) )
    Thanks a lot for the answer :)
