Print Screen key not copying screenshots, Paste option greyed out in Paint and other apps
-=[OLO]=- 55565 7
  • #1 2671096
    -=[OLO]=-
    Help: 36
    Rate: 129
    I cannot take a screenshot with the Print Screen key.
    Once, after pressing Print Screen, I entered, for example, Paint and pasted a screenshot. Now, however, I can not do that, neither in Paint nor in any other program "paste" is not active.
    Maybe someone has encountered this problem and knows how to fix it?
  • #2 2671199
    Strit1
    Help: 15
    Rate: 13
    check other keys. I have the inscriptions mixed up and Pause Break works like PrtSc. And so it was originally on the keyboard
  • #3 2671324
    -=[OLO]=-
    Help: 36
    Rate: 129
    For me, the subtitles are not mixed up. The Print Screen key previously worked as normal. The key is also not damaged. When I press it in Word, the print window pops up.
  • #4 2671575
    tzok
    Help: 3177
    Rate: 6558
    Well, you have printing attached to it instead of Print Screen, because normally when you press it in Word, nothing happens, i.e. it takes a screenshot to the clipboard and no print window pops up.
  • #5 2672276
    -=[OLO]=-
    Help: 36
    Rate: 129
    OK, but how to make it normal.
  • #6 2672567
    maciek_slon
    Help: 143
    Rate: 27
    maybe if you have the auto-start office assistant turned on, turn it off. this is my first thought.
  • #7 2673049
    -=[OLO]=-
    Help: 36
    Rate: 129
    Office assistant? What's this?
    I don't see anything like that on the highway.
  • #8 9931433
    mgraphic
    I know it may be ridiculous, but I was just struggling with the same problem and ....
    I checked if PrintScreen is not connected to the printing function, so I tried it on the first open program. And guess what? The normal function of the key is unlocked, so now I can take screenshots as usual.
    Well, unless it's a coincidence, but it's worth trying :)
    Archeology? [piterus99]
The user is experiencing issues with the Print Screen key, which no longer allows them to take screenshots or paste them into applications like Paint. Initial suggestions included checking if the Print Screen key is misconfigured or if it is linked to a printing function instead of its intended screenshot function. The user confirmed that the key previously worked correctly and is not damaged. Further advice included disabling any auto-start features that might interfere with the key's functionality. A successful resolution was reported by another user who found that using the Print Screen key in a different program restored its normal function, suggesting that the issue may be program-specific.
