Corsa C 1.2 - Warm Air Issue: No Heat, Overheating & Coolant Loss after Cardboard Grill Fix
MrDoimer 9732 5
  • #1 16844689
    MrDoimer
    Help: 271
    Rate: 125
    I gave a girl in Corse who, since the temperatures dropped below 10 ° C, is underheated on the road and still has 80 ° C. The city is ok. The girl's father came up with the brilliant idea of inserting a piece (ie "piece" because the carton was double and the size larger than the cooler ...) of the cardboard between the grill and the coolers. The effect was sensational, but it wasn't until 8-10km that the girl realized that the temperature indicator showed max. as much as he can. She pulled down to the station, opened the mask, and there, of course, half wet in the coolant. She poured in liquid, removed half of the cardboard and reached home at an average temperature of 100 ° C. I told her to turn on the heating to the max, but after 5km from leaving the station she felt that cold air was flowing, not warm (it had been warming before). Now, after the liquid in the tank has cooled down, I refilled it, warmed up the engine and there is still no warm air. What could happen?
  • #2 16844724
    tkaczu1
    Help: 22
    Rate: 92
    Hello. Thermostat for exchange you probably have. At low temperatures. cooling is on a small circuit and then the car catches the temperature faster, and after setting the radiator the engine had no cooling.
  • #3 16844733
    sk700
    Help: 173
    Rate: 420
    What does the heater thermostat have? Add fluid and bleed it properly ...
  • #4 16844770
    tkaczu1
    Help: 22
    Rate: 92
    This is because the engine can not catch the right temperature, a colleague clearly wrote that after reaching the temperature was good so why the application for airing.
  • #5 16844777
    MrDoimer
    Help: 271
    Rate: 125
    100C he has because the girl removed half of this cardboard box, and the other half was because it was inserted so that it could not be removed.
  • #6 16844809
    tkaczu1
    Help: 22
    Rate: 92
    well now you actually have to bleed because when the liquid got out, it got air, but also check the thermostat. I also have such a corsa and I never have a problem with the engine warming up even at -20.
