Corsa C 1.2 2004 - Rear Right Heated Drum Wheel Issue After New Jaws & Brakes Replacement
kryst16 15630 15
Why does the rear right drum brake on a 2004 Opel Corsa C keep overheating after fitting new shoes and adjustment?
The overheating was caused by the shoe pull-off spring between the shoes and the self-adjuster being almost 1 cm longer on the right side, which let the self-adjuster keep expanding the shoes until they dragged. Replacing that spring with the old one, which matched the left side, made the problem disappear [#16956456] The self-adjuster itself should not be able to randomly spread the shoes if it is fitted correctly, so the assembly should be compared side by side with the other wheel [#16933328] The key lesson is to check new parts carefully before assembly, even if they look correct [#16956456]
  • Self-adjuster overexpanding rear drum brakes
    #1 16932183
    kryst16
    Help: 7
    Rate: 261
    I have a problem with the Corsa C 1.2 2004 car, drums without ABS on the back.
    After replacing the jaws with new ones, the drum of the rear right wheel began to heat up.
    What I've checked so far:
    * Jaws are new, drums without edges, all springs are new, everything is thoroughly cleaned, the self-adjuster works without any resistance.
    * All 100% well assembled.
    * Brakes bleed.
    * The cylinder is pressed in easily, I can do it with my fingers.
    * I rather ruled out the manual rope because when I lift the car you can hear a slight rubbing, the rope at the wheel is loose, even when I push it into the drum by force, the rubbing does not go away.
    The problem is strange in that when I adjust the self-adjuster so that I can easily put the drum on, there is no wiping, the manual works, but after a few brakes, the self-adjuster widens the jaws and heating begins, what could be the reason?
    I am sure that the self-adjuster expands because I took photos after assembly and after another disassembly when after a few days it started to warm up again and it was evident that the self-adjuster widened the jaws by a few thread turns.
    Then, after driving 20-30 kilometers, the drum is so hot that it is hard to touch it.
    I write here because I no longer have an idea what could be the reason, several times I undressed, folded, checked, one around 100% ok, and the other heats up. I also have new slides on the cable at the back of the beam.
    Not my picture but I have it submitted in the same way:
    I am asking for advice. I am slowly coming to the conclusion that the self-regulator works too lightly (too well cleaned) but is it possible ... The only thing I have translated is the old washers under the plates moving the self-regulator.
  • #2 16932507
    kacu666
    In my opinion, the linings on the jaws get through. After some time it should be ok I had the same in corsie b 1.0. And the big difference between the wheels in temp?
  • #3 16932628
    kryst16
    Help: 7
    Rate: 261
    Unfortunately very large.
    The left wheel barely warm, and the right wheel burns after a 20-30km stretch.
    As I unscrew it, it can be seen that the regulator itself has expanded the linings, I twist it manually, brakes a little and the problem repeats.
    kacu666
    there should be a cable tension adjuster underneath the car. check that they are equally stretched. You should drive and check from 80km / h to 40 km / h several times.
    I have no more ideas :D
  • #5 16932721
    kryst16
    Help: 7
    Rate: 261
    Corsa C has cable adjustment only on the jack, Corsa B had underneath.
    I also have no ideas, that's why I wrote here.
    The strange thing is that the self-adjuster widens the jaws until they are rubbed, there should probably be some slack.
    I will try to ride a few days and see if they arrive but I doubt it.
    kacu666
    is between wheels
    and Corsa C 1.2 2004 - Rear Right Heated Drum Wheel Issue After New Jaws & Brakes Replacement
  • #7 16932926
    kryst16
    Help: 7
    Rate: 261
    There is no regulation, it is only a cable connector.
    Yes it is ridiculously done that the cable from one wheel is moving forward and the other is attached.
    In Corsa B it was already better solved.
    The Corsa C only has a screw on the hand lever. :D
  • Handbrake cable guide on swingarm may bind
    #8 16933020
    Tradelectra
    Help: 5
    Rate: 9
    In corsie C you like to cut the hand cord into the guides on the swingarm, something like that
    this could be one of the reasons.
    https://www.google.pl/search?q=prowadnica+lin...52C_&usg=__KQik9Z1MSKPBtHM3mKgHGJwkm9M%3D&sa= X & ved = 0ahUKEwiY8t7m_LvYAhWJCJoKHY1KBA0Q9QEIODAB # imgrc _ =
    Hurtownia Tradelectra Agnieszka Bieńka
    Kusocuńskiego 16/1, Toruń, 87-100 | Company Website: www.tradelectra.pl
  • #9 16933210
    kryst16
    Help: 7
    Rate: 261
    I replaced these two guides because I was damaged. (They are located on the rear suspension bar, one per side.
    A moment ago I looked at the line once more and I have a suspicion that it may be her fault because in the places of these guides it is slightly rubbed (rubbing against metal when there were old guides), I will replace it or disconnect it and I will eat. Let's see if this is it.
    Check self-adjuster fit and drum contact symmetry
    #10 16933328
    enhanced
    Help: 963
    Rate: 883
    Insert a photo of your system and not someone else's because there is no option for the self-adjuster to expand the jaws after correct insertion - either the self-adjuster is made or (more suited) that you put on the drums and come in with too much looseness (though this should not cause heating problems) but with weak braking) and they should be tight - check the self-adjuster again (photos after removing it is welcome) and when putting on check if the drum reaches tight all over the jaws and not just on one side.
    The self-adjuster as it is correctly fitted cannot suddenly twist because it is physically impossible that with tight insertion it will have enough slack to even pass by one leap. Something wrong with him - maybe buying a new one? Maybe compare both self-regulators or not.
    Did it come off without a problem when downloading this drum?
    The link is symmetrical because you mentioned something different than on this diagram?
  • Sticking handbrake cable likely causing drum heating
    #11 16933661
    kryst16
    Help: 7
    Rate: 261
    It also puzzles me a lot but I think I know what it is.
    Probably the line blurs after a few brakes in the slide by the beam and does not withdraw it completely from the drum, which is why it seemed loose because it was loose under the car and between the drum and the slide tense, I noticed now damage to the teflon on the line and a slight abrasion. in the place where it slides on the beam.
    I will also exchange links because it is not a big cost.
    It goes down without problems, before the drums had a slight edge which I wiped perfectly.
    I fold it in such a way that the drum enters tightly with a gentle wiping, but then after folding as lightly as I knock on the drum it no longer rubs, heating only appears after a few brakes.
    The cable is the same as in the diagram, but a colleague above looked badly saying that there is adjustment, it is only the connector that connects the drum cable with that from the brake lever.
    Thank you for the advice, I will replace the cable and see if it helps, the cost is not big and now it clearly indicates it because when I unhooked the cables by the reels themselves, it did not heat up.
    zibi999
    Help: 10
    Rate: 60
    And what color you have brake fluid should be very bright. Maybe the fluid has overheated and the outdated fluid has gone down somewhere.
    The cost of replacing the fluid is not great, I also provide the cheapest solution that can help in removing the fault.
  • #13 16947109
    kryst16
    Help: 7
    Rate: 261
    I have a new liquid, but I poured DOT 3 because I couldn't get another one, it shouldn't affect?
    In the near future I will replace the cable and see if the problem goes away.
  • #14 16954225
    kryst16
    Help: 7
    Rate: 261
    I exchanged links, unfortunately the problem remained.
    Tomorrow I will give pictures of the inside of the drum, I have no idea what it can be because I think everything is 100% well assembled.
    I suspect only the cylinder and self-regulator.
    The cylinder can be squeezed with fingers.
    Unless the jaw compression spring is weaker than the old one ...
    The fault occurred after replacing the jaws and the master cylinder.
    I used to change my jaws in this car (90,000 km ago) and there was no problem.
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    Maybe the bearing heats the entire hub together with the drum?
  • #16 16956456
    kryst16
    Help: 7
    Rate: 261
    100% no, when I pick up the car and turn the wheel, they rub their jaws, when I hit the drum with a hammer they stop a little. And the drum is hotter around and on the sides than in the center of the wheel.
    Today I will dismantle it, take pictures of the assembly, and for tests I will replace what I can with the left wheel.
    I will also check the cylinder again and check the jaw compression spring because maybe the new one is weaker than the old one.
    Greetings.
    Added after 14 [hours] 42 [minutes]:
    Explained.
    The reason for the heating drum was that the jaw puller spring (the one that squeezes them between the jaws at the height of the self-regulator) was in the right wheel longer by almost a centimeter than that in the left wheel.
    Strangely, I did not notice it assembling everything the first time because the springs and jaws were new.
    I replaced the spring with the old one (the same length as the one in the left wheel) and the problem has disappeared so far.
    So the conclusion that before assembly you even have to check new parts is everything is 100% ok.
    Greetings.
The discussion revolves around a heating issue with the rear right drum wheel of a 2004 Corsa C 1.2 after replacing the brake jaws and drums. The user reports significant temperature differences between the left and right wheels, with the right wheel overheating after a short drive. Various checks have been performed, including ensuring the self-adjuster functions correctly and that all components are new and properly assembled. Suggestions from other users include checking the cable tension adjuster, potential issues with the self-adjuster, and the possibility of a faulty brake line. Ultimately, the user discovers that the problem was due to a discrepancy in the length of the jaw puller spring, which was resolved by replacing it with a correctly sized spring from the left wheel.
TL;DR: Hot rear drum after new shoes on a Corsa C was traced to a return spring that was ~1 cm longer; “The jaw puller spring was longer by almost a centimeter.” [Elektroda, kryst16, post #16956456] Why it matters: This FAQ helps Corsa C owners quickly diagnose a single hot drum after brake work and avoid repeat tear-downs.
What usually causes one rear drum to overheat right after new shoes on a Corsa C 1.2?
A mismatched or weak return spring can hold the shoes out, causing drag. In the solved case, the right-side puller spring was about 10 mm longer. Replacing it with a correct-length spring eliminated the heat. The self-adjuster then behaved normally. [Elektroda, kryst16, post #16956456]
How can I quickly confirm the issue without special tools?
Jack up the wheel, spin it, and listen for rubbing. Tap the drum lightly; if drag reduces briefly, the shoes are sticking. Compare shoe return spring lengths side-to-side and replace any overlong spring. This three-step check mirrors the solved case. [Elektroda, kryst16, post #16956456]
Could a bad wheel bearing be the reason my drum is hot?
It’s an edge case, but in the documented fix the bearing was not the cause. The heat concentrated at the drum’s rim and sides, consistent with shoe drag, not a hub bearing. Shoe tap reduced rub, further pointing to the brake hardware. [Elektroda, kryst16, post #16956456]
Where do I adjust the Corsa C handbrake cable?
At the handbrake lever only. The underbody junction is merely a connector, not an adjuster. This differs from the Corsa B layout, which has underbody adjustment. Set cable tension at the lever after verifying free shoe return. [Elektroda, kryst16, post #16932926]
How do sticky cable guides cause a hot drum?
Rear beam guides can cut into the cable’s Teflon, preventing full return. The author observed abrasion and that disconnecting the cables stopped the heating, confirming cable-induced drag as a confounding factor to check. Replace damaged guides or cables. [Elektroda, kryst16, post #16933661]
What is the self-adjuster in these drum brakes and how should it act?
The self-adjuster expands the shoes as linings wear. In this case it advanced after several brakes because shoe return was compromised. With correct springs and setup, it should not over-tighten after a few stops. [Elektroda, kryst16, post #16932183]
How tight should the drum feel on refit?
Fit the drum so it goes on snug with a light wipe across both shoes, not just one area. If correctly assembled, the adjuster should not wind itself tighter unexpectedly. “As it is correctly fitted [it] cannot suddenly twist.” [Elektroda, enhanced, post #16933328]
My self-adjuster ‘keeps expanding’ after a few brakes—what am I missing?
Inspect shoe return springs first. An overlong or weak spring lets the shoes sit out, so the adjuster advances to remove imagined clearance. Matching spring lengths cured the auto-expansion and heat in the solved case. [Elektroda, kryst16, post #16956456]
Will changing brake fluid fix a hot drum?
Fresh fluid is good practice, but fluid wasn’t the fix here. The overheating was resolved by correcting the shoe return spring length, indicating a mechanical, not hydraulic, cause. Use fluid service to baseline the system. [Elektroda, kryst16, post #16956456]
Is DOT 3 fluid to blame for the overheating?
No evidence here. The car had new fluid, and the ultimate fix was replacing an overlong return spring. Focus diagnostics on mechanical drag before fluid type. [Elektroda, kryst16, post #16956456]
Why does tapping the drum reduce rubbing for a moment?
A light tap can let slightly stuck shoes relax against the springs, reducing drag temporarily. This behavior points to return spring or shoe alignment issues rather than hydraulics. [Elektroda, kryst16, post #16956456]
How big a temperature difference signals trouble?
A clear red flag is one side barely warm while the other side feels burning hot after a short drive. That asymmetry indicates uneven drag or adjustment. [Elektroda, kryst16, post #16932628]
What changed right before the problem started in the reported case?
The owner replaced the shoes and the master cylinder. The issue appeared afterward and was solved by correcting a mismatched shoe return spring, not by further hydraulic work. [Elektroda, kryst16, post #16954225]
How do I test if the handbrake cable is the culprit?
Inspect for sheath abrasion at the rear beam guides. Temporarily disconnect the cable at the drum and road-test cautiously. If heating stops, replace the damaged cable and guides. [Elektroda, kryst16, post #16933661]
What three-step process should I follow to fix a hot rear drum on Corsa C?
  1. Spin the wheel and tap the drum to confirm shoe drag.
  2. Compare right vs left return spring lengths; replace any overlong spring.
  3. Reassemble and road-test; confirm temperature symmetry side-to-side. [Elektroda, kryst16, post #16956456]
