What diagnostic program for VW POLO 9N 2004R on OBD II KKL cable
xmucekx 10809 6
  • #1 16845207
    xmucekx
    Rate: 44
    Hello! I have a question for which version of the VCDS diagnostic program VW POLO 9N 2004R will the program work on the OBD II KKL cable ?? I mean Win 10 x64 works? VAG-COM 409 does not work on Win 10, what VCDS cable for this? on WIN 10?
  • #2 16845235
    sk700
    Help: 173
    Rate: 420
    Only VCDS lite.
  • #3 16845733
    xmucekx
    Rate: 44
    VCDS lite is also weak on 10 x64 wines. I have this cable:
    / Cable-diagnostic-interface-vag-com-KKL-RX-VW /
    and Polish vag does not work connection on XP and writes establishing a connection and nothing counts to 1-2 and nothing. And I'll add that lux works in VAG-COM
    Moderated By CameR:
    I deleted the link to Allegro
    Reg. 3.1.18. Do not send links that will become inactive after some time. This will cause the discussion to lose any meaning.
  • #4 16845833
    sk700
    Help: 173
    Rate: 420
    Set up ports.
  • #5 16845998
    xmucekx
    Rate: 44
    I set and nothing. A vag 409 works, maybe the cable doesn't match the program ??
  • #6 16846025
    sk700
    Help: 173
    Rate: 420
    You have VCDS or VCDS lite because these are two different programs and only lite works with this cable.
  • #7 16846090
    xmucekx
    Rate: 44
    I don't use vcds lite. Only vag com 409 and I would like Polish vag to work properly on 10 x64 win
The discussion revolves around the compatibility of the VCDS diagnostic program with the VW POLO 9N 2004R using an OBD II KKL cable on Windows 10 x64. Users suggest that only VCDS Lite is compatible, but it has limitations on Windows 10. One user mentions using a specific KKL cable but experiences connection issues with VAG-COM 409 on Windows XP. There is confusion between VCDS and VCDS Lite, with the consensus that VCDS Lite is the only version that works with the KKL cable. Users express frustration over the lack of functionality of Polish VAG software on Windows 10.
