Junkers vs Electric Heating: Hot Water Cost Calculator & Comparison Forum Discussion
fatoom87 18078 10
  • #1 16847797
    fatoom87
    Does anyone from the Forum have a cost calculator for heating hot tap water?
    I'm thinking about throwing away Junkers and switching to electric heating.
  • #3 16848699
    fatoom87
    From what I see it with my consumption of hot water at the level of 3-4 m3 a month is the fact that the electrically come out more expensive. Because about PLN 100 / month.
    Currently, it is the gas cost 112 PLN / 2msc. The gas bill obviously includes consumption by a gas kitchen.
    I suppose, however, that water consumption should fall and it will not be meaningless for bills.
    Instead of manually washing, the dishwasher will be in place and instead of the tub there will be a shower.
    The cost of buying an electric boiler is also smaller than a reasonable gas junker.
    And security ... I will skip this because it is a psychological comfort.
    Thanks for the calculation.
  • #4 16849161
    lukiiiii
    Help: 82
    Rate: 391
    Kraniec_Internetów wrote:
    0.44kWh and it will cost 25gr.
    In the G12 tariff 15gr.
    I used to count and work the same way as my colleague Kraniec_Internetów counted, about 2gr / per liter of water temp 70 * C, water from the boiler 80L, night tariff or G12, heating at night from 4:30 to 6 and on the day from 14-15. And in low daylight hours you can also get a dishwasher and a washing machine.
    There is no gap between gas and G12 tariff. It is a bit more expensive or not at all.
  • #5 16849173
  • #6 16849732
    fatoom87
    Friend Lukiiiii
    What kind of boiler do you have? Can you recommend something?
    I will not have any problems with the change of the tariff, the renovation of the electrical installation awaits me.
  • #7 16849758
    Ryszard49
    Help: 312
    Rate: 1004
    Kraniec_Internetów in my opinion the most expensive is heating with fuel oil.
  • #8 16849785
  • #10 16850530
    Ryszard49
    Help: 312
    Rate: 1004
    rafbid , and here I confirm what I have already written about the cost of heating, but that I have a different opinion about the costs of electric water heating. I use Siemens DE1518628 Electronic exclusive instantaneous water heaters, and here I would rather find myself at a decent cost. I set them up only because of the ability to quickly set the desired water temperature with the help of four buttons.
  • #11 16851851
    lukiiiii
    Help: 82
    Rate: 391
    LEMET 80L. Electricity bill in summer for 3 people 160zł / 2mc
✨ The forum discussion revolves around the cost comparison between Junkers gas heating systems and electric water heating solutions. Users share insights on the expenses associated with heating hot water, highlighting that electric heating tends to be more expensive in Poland due to high electricity costs. Calculations provided indicate that heating 40 liters of water with electricity costs approximately 1 PLN, while users report monthly costs of around PLN 100 for electric heating compared to PLN 112 for gas heating over two months. Some participants mention the advantages of electric boilers, including lower initial purchase costs and the psychological comfort of safety. However, others caution about the high energy bills associated with electric heating, with one user noting a significant reduction in costs after switching to a heat pump. Brands and models discussed include Siemens DE1518628 and LEMET 80L.
