Golf 4 1998 - The alarm sounds when you close the car with the remote control.
Kubasss21 6711 1
  • #1 16855223
    Kubasss21
    Hello, I am asking for help, I immediately write that I know that there are a lot of topics about coding etc. but none of the methods I found works.
    I own golf 4 from 1999, imported from Switzerland with 1.8T engine
    I have 2 keys for it, both were functional but in:
    -1 The key changed the housing, and then closing and opening the car with the key stopped working.
    -2 The key operated to this day, I decided that I would try to fire it today with 1 key and go to work, unfortunately, immediately after turning 1 key turned on the alarm and I had to run quickly after 2 so as not to stimulate all neighbors.
    When I got to work I wanted to close the car, but unfortunately after clicking the "Close" button an alarm sounds, so my 2 key broke. Opening is working fine and closing is triggering an alarm. Could you please help me. Any advice?
    Thank you in advance for your help, if someone "fix" me my key can count on some small cash reward, we can get along easily, I'm honest.
    I work between 7-18 so I can't go to "Specialists" So I count on you, I am asking for help. Regards :)
  • #2 16859562
    Cinek_Barczewo
    Rate: 26
    Hello. I will start with the fact that I also used to golf IV in my time, so I got to know him a little bit. Probably the fault for triggering the alarm when closing can be blamed on one of the microswitches in one of the doors, the tailgate, or the switch located in the front bonnet bolt (the car "sees" the door or flap open). My question is whether after closing the door, the interior lighting goes out or do the door lights go out? Did you connect the car to the computer? The second thing, the remote control in the key, maybe just decoded after replacing the housing (removing the battery for a long time). If you have two keys, it is possible to code the remote control manually using a second (functional) key. Podrawiam
