VW Golf IV - Central does not work with remote control (pocket knife)
ABRAM_TJE 6453 2
  • #1 16424170
    ABRAM_TJE
    Rate: 18
    Car mates from 2004, 4 windows, 8 cushions, etc. Key pocketknife.
    It worked from 2-3 meters, I replaced the battery - it improved for 3 days.
    Now closing does not work with remote control. the key is oki.
    the safe diode on the driver's door is not lit and the buzzer from the lights is not working. the light in the driver and other door works.
    this microst contact for the lock's working order, the lock replaced with a new one - with no effect.
    There are no errors
    During the element test, the LED also blinks.
    the buttons when I press also says ok.
    Replaced comfort module - no improvement.
    I checked the pilot with a pilot tester - oki works.
    I planted the remote control on a functional bank from another car and learned - no effect
    Someone will tell me where to bite?
    Wires between the body and the door whole.
    New comfort established, 2 learned remote controls, in block 014 sees that the remote controls are working.
    Learned as 3 and 4. Previously, they were as 1 and 2.
    ONLY NOW ENTERING THE COMFORT ADAPTATION 01 - the number of keys is 1 and by entering 2 or 3 or 4 and clicking TEST nothing changes.
    Counting is still 1. It cannot be changed from the beginning.
    I teach using the method:
    1 scan on ignition
    the second in the driver's door and mechanically close to the right, then press the Unlock button for a minimum of 1, 2, 3 or 4 times for a second and then after a minimum of 5 seconds again briefly Unlock. Of course, the siren is heard for a split second.
  • #2 16425043
    decybel91
    Help: 1024
    Rate: 4230
    Damaged door lock or harness in the door, the LED on the driver's door must be on.
    Does it have a driver in the windscreen motor? Maybe he is down.
  • #3 16426497
    ABRAM_TJE
    Rate: 18
    2 new undercoats did not help.
    The beam is good in the door, the cut insulation is checked and it is great.
    The windshield motor just substituted another efficient and no reaction
