VW Golf 4 (1999) 1.9 TDI 90 KM Fires & Goes Out: Remote Control, Immobilizer Issues, Elblag Area
ANYRIDGE 14259 6
  • #1 16744202
    ANYRIDGE
    Golf 4 1.9 tdi 90 KM 99 year, everything worked, the pilot crashed and the wife opened the key as if she had been driving for one month. I have repaired the remote control, closes and opens but still the same. Anyone have any idea ?? Maybe an immobilizer? I am from Elblag, maybe somebody knows something in this field?
  • #2 16744211
    spinacz
    Help: 1204
    Rate: 2648
    Everything indicates 99% that it is immo, when I start it I understand that it comes from 2 seconds and goes out?
  • #3 16744219
    Heinzek
    Help: 554
    Rate: 494
    The immo indicator lights up? goes out after a while?
  • #4 16744867
    ANYRIDGE
    After turning the ignition, the lights and the immo light up normally and then go out ... Then nothing shines
    It's like: I light up, catch it but it doesn't work for 1 or 2 seconds. It's like something inhibiting it ... And what if immo what is being done in this situation? exchanges, recodes ?? best to leave it out of the damn thing because it's a very old car
  • #5 16744964
    spinacz
    Help: 1204
    Rate: 2648
    If you ask about such things, all you have to do is give your car to the workshop.
  • #6 16745170
    ociz
    Help: 1378
    Rate: 3475
    You lost your transponder with the key.
  • #7 16745999
    bodzio012
    Help: 161
    Rate: 779
    And don't you smoke white for these 2 seconds? Sometimes when you flap you go out. it will cut the same fears.
✨ The discussion revolves around a 1999 VW Golf 4 1.9 TDI experiencing starting issues, where the engine fires briefly for 1-2 seconds before shutting off. The owner suspects an immobilizer problem, especially after the remote control was repaired but did not resolve the issue. Responses suggest that the immobilizer may be the culprit, with indications that the immo light behaves normally before the engine fails to stay on. Suggestions include checking for a lost transponder key and considering professional assistance for repairs or recoding the immobilizer system.
