Peugeot 607 2.0HDi 136HP 2007 - No power. Turbo pressure and location
16968 16
Why does a Peugeot 607 2.0 HDi 136hp have no power and no turbo boost after the FAP was removed and the turbo was regenerated?
Your lack of power is most likely caused by an air/turbo control problem, not by the FAP delete itself: the measured data show about 88% turbo pressure demand but only around 10% actual turbo position, so the turbo is not being controlled correctly [#16858156] Check the turbo vacuum actuator, linkage, and variable-geometry mechanism for sticking or soot/ash buildup, because these parts often seize and may only need cleaning or freeing [#16858156] Also inspect the whole intake system for leaks, the air filter, intercooler, throttle flaps left in place after the FAP removal, and the related sensors and wiring: boost pressure sensor, air temperature sensors, turbo position sensor, EGR position sensor, and MAF [#16858156][#16860068] One reply also suggested the map may need correction because the turbo setpoint is too low [#16857369], but the thread mainly points to a mechanical or airflow fault rather than a successful turbo regeneration [#16859855][#16858156]
  • #1 16855867
  • #2 16855878
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Restore original condition and repair. Or upload a DPF-of which will cope with engine control. have you checked how many error tables have been stripped down?
  • #3 16856348
  • #4 16856403
    Marek Sp
    Rate: 139
    This is how the effect is treated, not the cause. Having a diagnostic interface and being able to read errors is not enough. Of course, that it can be repaired, it is a successful unit from which you can squeeze even 170 ponies after fashion and walk flawlessly but .... and here it is, but that you need to know and maybe you know what the driver is there?
  • #5 16857219
  • #6 16857255
    Marek Sp
    Rate: 139
    OK, I already know which one
  • #7 16857369
    robi1214
    Help: 151
    Rate: 869
    Map to be improved. Too low turbo pressure set.
  • #8 16857433
    Marek Sp
    Rate: 139
    I would argue because I talked to the owner and was weak from the purchase, I think that first you need to do full mechanical diagnostics because without proper combustion in the combustion chamber there will be no
  • #9 16857441
    robi1214
    Help: 151
    Rate: 869
    There may be more than one malfunction, look at the turbo set at 3000 rpm. I already had this case after a fap.
  • #10 16857452
    Marek Sp
    Rate: 139
    It's just that since the purchase it was weak and for this he was cut FAP (I do not know why) map and I will collect the parameters in my own way as I exclude the mechanical part there, even the regenerated turbine was so calm and not treating the symptoms
  • #11 16858156
  • #12 16859164
    Marek Sp
    Rate: 139
    Very nice lecture and you are right in what you write so much with
    - DPF cut out there is wet with eloys and they don't clog up
    - compressor regenerated
    and probably something else and no effect.
  • #13 16859634
  • #14 16859755
    adam7009
    Help: 656
    Rate: 1635
    KotBury2 wrote:
    Although it applies to the 1.6 HDI DV6 engine, the principle of operation is identical.
    just the opposite
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #15 16859855
  • #16 16860068
  • #17 16860138
    Marek Sp
    Rate: 139
    You are right because I intend to disassemble everything and verify it step by step. A bit of work but it should bring results
The discussion revolves around a 2007 Peugeot 607 2.0HDi experiencing significant power loss, akin to driving without turbo assistance. The user notes that the FAP (particulate filter) was removed and deleted from the ECU, yet power issues persist. Observations include no turbo pressure, constant turbo position, and abnormal temperature readings from the flow meter. Various repairs have been attempted, including turbo pressure sensor replacement and turbo regeneration, but without success. Participants suggest a thorough mechanical diagnosis, checking for air intake leaks, and verifying the functionality of multiple sensors, including the air boost pressure sensor and mass air flow meter. The importance of restoring the original condition and addressing the root cause rather than just symptoms is emphasized.
TL;DR: Peugeot 607 2.0 HDi “no power” often traces to stuck VTG/actuator: ECU requests 88% turbo, but copy shows 10%. Fix usually involves cleaning and restoring vacuum control—“Just washing and cleaning.” [Elektroda, Anonymous, post #16858156]
Why it matters: This FAQ helps owners and techs quickly isolate boost, intake, and FAP-off tuning faults causing limp performance on the 2.0 HDi RHR.
How do I start diagnosing a 607 2.0 HDi with no power?
Work the intake and boost path end to end. Check air filter, intercooler leaks, hoses, and throttling butterfly. Verify sensor circuits, not only sensors: boost pressure, two air temp sensors, turbo copy sensor, EGR stroke sensor, and MAF. Fix wiring faults before parts. [Elektroda, Anonymous, post #16860068]
What does “turbo demand 88% but copy 10%” indicate?
The ECU commands high vane position, but the actuator or VTG mechanism does not move. That mismatch means a stuck VTG, failed vacuum supply/solenoid, or linkage issue. “You should therefore lean again over the turbocharger.” Clean and free the mechanism. [Elektroda, Anonymous, post #16858156]
Where is the turbo control and how does it work on this HDi?
A vacuum “bellows” actuator moves linkages that set variable vane geometry on the turbo. Soot can seize the lever and gears. Cleaning the actuator linkage and ensuring solid vacuum restores movement and boost. [Elektroda, Anonymous, post #16858156]
Could a bad DPF/FAP-off tune cause low boost targets?
Yes. A poor map can set turbo pressure too low, limiting performance even with good hardware. Restoring stock or correcting the calibration fixes the setpoint. [Elektroda, robi1214, post #16857369]
Why does power drop around 3000 rpm on full throttle?
Logged data shows air setpoint 518 while measured is 278 at 3000 rpm. That gap points to lost boost from VTG control faults, intake leaks, or airflow restrictions. Investigate those first. [Elektroda, Anonymous, post #16855867]
Should I clean or regenerate the turbo?
Start with cleaning and freeing the VTG and linkage. Soot deposits glue the mechanism and kill boost. “Just washing and cleaning.” If the core is damaged, pursue proper regeneration with calibration. [Elektroda, Anonymous, post #16858156]
Which sensors most often cause false low‑air readings?
Check the boost pressure sensor, both intake air temperature sensors, the turbo position (copy) sensor, EGR stroke sensor, and MAF. Inspect wiring and connectors because the ECU evaluates whole circuits. [Elektroda, Anonymous, post #16860068]
Can an air filter or intercooler leak really cause limp power?
Yes. A choked filter or small intercooler leak drops available air, forcing low measured flow versus target and triggering limp behavior. Repair leaks and replace the filter before deeper work. [Elektroda, Anonymous, post #16860068]
What is FAP and how is it different from DPF?
FAP is the French wet filter system using Eolys additive; DPF is the dry term. Even with FAP deleted in software, leftover air throttles can still disrupt airflow if not addressed. [Elektroda, Anonymous, post #16859634]
After FAP removal, do I need to modify any hardware?
Yes. Neutralize or reconfigure the hot/cold air throttling valves tied to FAP regeneration. Leaving them active can starve the engine of air and kill power. [Elektroda, Anonymous, post #16858156]
What ECU runs the 2007 Peugeot 607 2.0 HDi 136 (RHR)?
It uses a Siemens engine control unit on the RHR-coded 2.0 HDi. This detail helps when selecting tools and maps. [Elektroda, Anonymous, post #16857219]
How can I verify a real turbo regeneration was done?
Ask to witness disassembly, cleaning, VTG calibration, and reassembly. Request documentation and sign‑off. If power is identical before and after, the work was likely not performed or another fault exists. [Elektroda, Anonymous, post #16859634]
My MAF shows −49°C but parameters show 17°C. What does that mean?
Conflicting intake temperature values indicate a sensor or wiring fault. The ECU may default and limit boost. Repair circuits or replace the sensor, then retest airflow. [Elektroda, Anonymous, post #16855867]
What quick 3‑step test can I run for VTG/vacuum faults?
  1. Hand‑vacuum test the actuator; confirm smooth full stroke.
  2. Command boost via scan tool; watch copy position track demand.
  3. Inspect/clean linkage and check the solenoid and vacuum lines for leaks. [Elektroda, Anonymous, post #16858156]
A mechanic says the turbo was rebuilt, but power is unchanged. What now?
Treat it as an unresolved fault. Verify VTG calibration, vacuum supply, intake leaks, and FAP‑related throttle states. Demand evidence of the rebuild steps and results. [Elektroda, Anonymous, post #16859634]
Should I revert to stock before further tuning?
Yes. “Restore original condition and repair.” Then apply a verified DPF‑off map if needed, ensuring correct boost targets and actuator control. [Elektroda, jurekk55, post #16855878]
