Peugeot 307 2.0 hdi 90KM - loses power and goes out
timmdawid 1641 2
  • Likely antipollution fault causing limp mode and stall
    #1 19788403
    timmdawid
    Hello. I am new here. And I have a question, it has probably already appeared somewhere, so I have a Peugeot 307, 2.0 HDI 90KM. I have a problem with it, the car drives and after driving some 5 to 10 km it loses power, and when I press the clutch pedal it goes out. After a while, I can fire it up and go on, but the same situation reappears. There was also an antipolution falut message. Anyone help something?
  • #2 19788558
  • #3 19788606
    beryas
    Help: 152
    Rate: 414
    most likely you have a problem with the fuel system and the controller is cutting off, but without a computer you won't know anything
