Office 2016 Key - Retrieving Last 5 Characters & Finding Full Product Key with Cscript
adsoft 52290 9
How can I retrieve the last 5 characters or full product key for Office 2016?
You can get the last 5 characters with the cscript script if you type it manually and run Command Prompt as administrator, but for Office 2016 the result may not match the key printed on the card because registration at office.com/setup can generate a different key. [#16858855] [#16858871] Another user confirmed that the script shows two keys and that the one in the Office.com account should be compared against the command output, not necessarily the original box/card key. [#16858886] [#16858903]
  • #1 16858824
    adsoft
    Does anyone have a way to read the key or at least the last 5 characters of Offica 2016. I've tried a lot of programs and a way with cscript
  • #3 16858843
    adsoft
    but not Office in 2016 version
  • #4 16858855
    djtommy
    Help: 38
    Rate: 41
    Did you copy the command from the page or manually entered using cscript?
    As I copied from the site it did not work, and as I entered the whole, it worked.
    And do you run CMD with administrator privileges?
    Have you tried this Belarc Advisor program?
    From 2013, he showed the last 5 characters.
  • #5 16858859
    adsoft
    I typed in manually and the script works like it shows the last 5 characters but unfortunately does not match how they would be invented: /
  • #7 16858871
    djtommy
    Help: 38
    Rate: 41
    But not matching what?
    Where does this office come from?
    If you bought in a store you probably had to register it at office.com/setup and there was generated a new key which 5 last characters should match what went in the CMD.
  • #8 16858872
    adsoft
    a large number of programs - all from google search with the content "office key reading" "office 2016 key reading" etc, etc.
    Not compatible with the key that I have
    djtommy
    Help: 38
    Rate: 41
    Shows 2 keys.
    Do you have the key from the card that was in the office box?
    Do you compare with the key you see after logging in to your office.com account?
  • #10 16858903
    adsoft
    ok I close agrees with what is after logging in :)
The discussion revolves around retrieving the last five characters of the Office 2016 product key using various methods, including Cscript and third-party software. Users share experiences with different key retrieval programs, noting that some, like Keyfinder, do not support Office 2016. A suggestion is made to use Belarc Advisor, which reportedly shows the last five characters. The author confirms that the Cscript command works but does not yield a matching key. The conversation highlights the importance of verifying the key against the one registered on office.com/setup and the key provided with the Office purchase.
