Pre-paid Red Bull Mobile, RBM 5: RWK & DIL Settings Expert Review & Updates Comparison
taxy 4047 9
How do I check whether RWK and DIL are configured correctly in RBM 5 after migrating a number?
No — the key problem is not the DIL setting, but that the number was handled in the wrong order and topped up with PLN 30 instead of PLN 50, which gives 30 days of outgoing validity instead of 100 days; for a normal RBM starter bought without migration from another operator, the usual RWK method does not apply [#16859364] If the number was migrated from another operator, the RWK/number-transfer bonus should be activated first on RBM 7/MNP, and only then should you switch to RBM to Card 5 with DIL, because RWK then carries over to the new tariff [#16859495][#16859735] The system checks the balance and whether RWK was activated before the migration, so you have to wait patiently for the change to settle [#16859735] In Play24, creating a new ticket is recommended; manual bonus activation is supposed to take only a few minutes, but in practice it may take longer [#16860569]
  • #1 16859169
    taxy
    I have a request, can someone who knows the subject well have a look at the screen, is everything OK when it comes to RWK and DIL in RBM 5? I do not understand everything, maybe there have already been some changes in relation to what was described by the mothers?
    best regards
    Pre-paid Red Bull Mobile, RBM 5: RWK & DIL Settings Expert Review & Updates Comparisonscreen.PNG (63.69 kB)You must be logged in to download this attachment.
  • #2 16859307
    makosuu
    Help: 369
    Rate: 370
    Have you activated the DIL service?
  • #3 16859357
    taxy
    Thanks for the answer.
    Yes:
    Pre-paid Red Bull Mobile, RBM 5: RWK & DIL Settings Expert Review & Updates Comparisonsreen2.PNG (30.67 kB)You must be logged in to download this attachment.
  • #4 16859364
    matek451
    Help: 4352
    Rate: 5808
    Basic, serious mistake, card charged for PLN 30 instead of PLN 50, therefore 30 days for outgoing instead of 100 days9 when topping up for PLN 500. RBM starter bought, so without using the RWK method using migration from another operator. Such starters are always topped up for PLN 50 every 100 days
  • #5 16859387
    taxy
    Hello Mothers,
    Thanks for speaking up.
    Fact, I missed something confused me. Let it di..li!
    I bought a T-Mobile starter, transferred the number to RBM 7 today, and changed the offer on Play24 to RBM 5.
    Do you have any idea what to do next? Should I take a new starter?
    matek451
    Help: 4352
    Rate: 5808
    And why did you not activate the number transfer bonuses on RBM 7MNP, including RWK https://www.redbullmobile.pl/sites/default/fi...REGULAMIN_OFERTY_PROMOCYJNEJ_%E2%80%9EPRZENIE % C5% 9A_NUMER_DO_RED_BULL_MOBILE_NA_KART% C4% 98_I_Receive_BONUS% E2% 80% 9D_3.02.2017.pdf The entire operation is performed for the CIP bonus. Only after that does he transfer to RBM to Card 5 with DIL. RWK switches to the new tariff and then it makes sense to top up for PLN 30.
  • #7 16859665
    taxy
    I activated. A At least I did my best to activate. There are four ways in the terms of the promotion:
    1.Choose and confirm on the telephone keypad the code: * 111 * 340 * 1 #
    2. send an SMS to 111: START.340
    3.Choose * 111 # on the telephone keypad, and then select the appropriate option in the promotions section,
    4.log in to your Play24 account (24.play.pl) and then select the appropriate option in the "Pa-
    kiety "
    The first one didn't work, I kept getting "Service temporarily unavailable. Please try again later." Even tried after a few hours.
    Second - I sent an SMS ... and nothing. He was killed?
    I also did not succeed with the third one, and the fourth one - I didn't find anything like that on Play24 (what is the "appropriate" option?
    Well, as it turns out, it's not that easy, especially as the operator's operation is not right, or at least not entirely - there are errors.
    After one attempt in a row - I returned after a few hours and already confused in this chaos, whether it works or not (bonuses) - I switched to the RBM 5 offer. I filed a complaint, but it won't do anything for sure.
    Well, that's it.
    matek451
    Help: 4352
    Rate: 5808
    In the case of activating a bonus or migrating to RBM to Card 5, you have to be patient, this is how it "works". Before switching to RBM to Card 5, the account balance is always checked and whether RWK has been activated on this number for migration from another operator.
  • #9 16859833
    taxy
    Yes, exactly - now I know it; (A few hours though - I did not expect, I must admit honestly ;) It's hard, now I have to repeat it with a different starter?
    Anyway, thanks a lot for helping me with this chaos :)
    Cahir09
    Next time on Play24, create a new ticket right away. Manually, you activate these bonuses within several minutes.
The discussion revolves around the RWK (Reimbursement for Number Transfer) and DIL (Discounted Incoming Calls) settings for Red Bull Mobile (RBM) 5. Users are seeking clarification on the activation process and potential issues encountered during the migration from other operators. One user reported a mistake in the top-up amount, leading to a shorter validity period. Others shared their experiences with activating bonuses and the challenges faced with the Play24 platform. It was emphasized that patience is required during the activation process, and users are advised to create support tickets for quicker resolution of issues.
