Seeking Recommendations for Most Profitable Pre-paid LTE Internet Operator
krzysztofferr 3264 10
Which prepaid LTE internet operator is currently the most cost-effective?
RBM 5 pre-paid with RWK and DIL is the recommended most profitable prepaid LTE option [#17010707][#17249824] You can buy the RBM 5 starter at a station kiosk for PLN 9 with a can of Red Bull, then top up PLN 50 every 100 days, which is about PLN 15 per month [#17011504] The suggested setup is to migrate from another operator to RBM, activate the number-transfer bonuses, and then change the tariff to RBM 5 so you get RWK (year-long account validity) and DIL (free LTE Internet) [#17011504] DIL is free, but the card needs PLN 30 on the account for it to work [#17011504] If you use the 600 MB package for PLN 5, activate it cyclically and remember to enable DIL, otherwise you will be limited to 32 kb/s [#17011504] An SMS should arrive when the service is being disabled, but you still need to watch the date if your modem does not receive SMS [#17011745]
  • #1 17010572
    krzysztofferr
    Rate: 8
    I would be grateful for your advice. Until now, I was using the Pre-paid Plus out of necessity (only 3G, I had coverage only from Plus) and bought starters on the alegro but after changing my place of residence I can afford any operator.
    So which operator is currently the most profitable?
    makosuu
    Help: 369
    Rate: 370
    RBM 5 pre-paid with RWK and DIL service. Look here on the forum and you will find.
  • #3 17011307
    krzysztofferr
    Rate: 8
    Thank you.
    RMB5 is the tariff? Could it be any Red Bull starter or a specific one?
    Judging by the prices on the alegro, these starters are probably not too easily available / common?
    makosuu
    Help: 369
    Rate: 370
    RBM 5 is a tariff. You can buy this starter at a kiosk at the station for PLN 9 with a can of redbull. Don't look at Allegro. The starter is supposed to be RBM5's best. Then you top up every 100 days for PLN 50, i.e. about PLN 15 per month. The trick with RWK is to migrate from another operator to RBM, activate bonuses for transferring the number, and then change the tariff to RBM 5. Then you have a card with DIL (Free LTE Internet) and RWK (Account Validity Year). Then you only charge 5 PLN per month to get the cheapest 600MB package for 5 PLN. The DIL itself is free, but you need to have PLN 30 in your account for it to work. You can also top up such a card once, and then you activate DIL every month. 600MB you turn on cyclic. You must remember to activate the DIL, otherwise you will get this 600MB and you will have a 32kb / s funnel.
  • #5 17011650
    krzysztofferr
    Rate: 8
    I understand. Regarding the second and subsequent activations of DIL, do they have to be exactly on the day on which the previous one ends, or maybe a day / several earlier?
    FrankAB
    Help: 29
    Rate: 63
    You cannot activate an active service.
  • #7 17011735
    krzysztofferr
    Rate: 8
    In other words, do I have to remember to do it manually?
    FrankAB
    Help: 29
    Rate: 63
    An SMS comes about disabling the service.
    You have to remember about the date if the modem does not receive SMS.
  • #10 17249500
    krzysztofferr
    Rate: 8
    Is this method still valid ?:
The discussion centers around finding the most profitable pre-paid LTE internet operator after the user switched locations. The RBM 5 tariff from Red Bull Mobile (RBM) is recommended, which includes RWK (Account Validity Year) and DIL (Free LTE Internet) services. Users can purchase the RBM 5 starter for PLN 9 at kiosks, and after activation, they can top up every 100 days for PLN 50, equating to approximately PLN 15 per month. To maximize benefits, users should migrate from another operator to RBM, activate bonuses for number transfer, and remember to manually activate DIL monthly to avoid service interruptions. The method remains valid as of the latest responses.
