Configuring TP-LINK TD-W8960N Router with ZHONE 2426A Modem for WiFi on Fiber Optic Internet
Maksymilian77 9537 6
  • Need WAN setup for TP-LINK TD-W8960N wifi bridge
    #1 16861233
    Maksymilian77
    I need help configuring my own modem router (TP-LINK TD-W8960N) to send wifi.
    Fiber optic Internet, from multimedia, comes out of their modem (ZHONE 2426A) via RJ-45 cable directly to the laptop and works like that, regardless of which laptop it connects with this cable.
    Now, connecting to the WAN port on my modem router, I don't know how to configure it to create a wifi network
    My router: Configuring TP-LINK TD-W8960N Router with ZHONE 2426A Modem for WiFi on Fiber Optic Internet
  • #2 16861263
    sylweksylwina
    Help: 1884
    Rate: 2357
    You connect to a LAN, not WAN port and turn off the DHCP server on TP-Link.
  • #3 16861296
    Maksymilian77
    I have disabled DHCP
    Just what next? :)
  • #4 16861315
    sylweksylwina
    Help: 1884
    Rate: 2357
    What is your modem IP address?
  • TP-Link and Zhone use the same 192.168.1.1 address
    #5 16861346
    Maksymilian77
    IP of the tp-link 192.168.1.1 modem
    The ZHONE multimedia modem IP is probably the same. (With rj45 connected to the laptop after entering this address I have access to the modem)
    When I connect rj45 to tp-link after entering this address, a tp-link modem pops up, but this is also not the rule, because sometimes I do not want to log in via admin / admin, but only ask for data to zhone (L: user h: multimedia today I found login details)
    sylweksylwina
    Help: 1884
    Rate: 2357
    Do this: leave the modem IP as it is, change the scope of the DHCP server in the modem, e.g. 192.168.1.10-192.168.1.100, IP TP-Link set 192.168.1.2
  • #7 16861504
    Maksymilian77
    I did as you wrote and WiFi works :) thanks so much for your help
The discussion revolves around configuring a TP-LINK TD-W8960N router to work with a ZHONE 2426A modem for WiFi access over fiber optic internet. The user initially connected the TP-LINK router to the ZHONE modem via the WAN port but was advised to connect it to a LAN port instead and disable the DHCP server on the TP-LINK. After confirming the IP addresses of both devices, the user was guided to adjust the DHCP settings on the ZHONE modem and assign a static IP to the TP-LINK router. Following these steps, the user successfully established a WiFi network.
