Technics SH-EH750: Connecting a Phone, Aux Input Settings & Playing Music through Towers
Darkevooo 23064 17
How can I make music from my phone play through the Technics SH-EH750 towers when connected to AUX?
Select the AUX source/input on the tower, but also make sure the phone is connected to the rear AUX IN sockets, not to any output/headphone jack on the tower [#16862713] [#16862833] [#16863173] The correct hookup is the phone’s audio output to the tower’s input, using a mini-jack to 2xRCA (2 cinch) cable [#16863173] [#16871129] If you connect output to output, the speakers will not play the phone sound [#16863173] After wiring it correctly, choose AUX on the remote or in the tower settings [#16862713] [#16871129]
  • #1 16862702
    Darkevooo
    I connected the phone through the aux input, the music in the phone plays and you can't hear it through the towers what you need to set in the tower settings to start receiving music from the phone
  • #2 16862711
    sylweksylwina
    Help: 1882
    Rate: 2355
    Change the audio source to AUX.
    DejoDejo
    Help: 35
    Rate: 75
    In the tower settings, select playback from the AUX input ;)
  • #4 16862721
    Darkevooo
    As I changed, nothing happened, I still couldn't hear it
  • #5 16862741
    sylweksylwina
    Help: 1882
    Rate: 2355
    Is the cable OK? Are the headphones connected to the phone working?
  • #6 16862745
    DejoDejo
    Help: 35
    Rate: 75
    Since you have changed and your phone still plays, it's either a telephone socket or a cable or a tower socket.
    Enter the phone and cable - it may come out that you have, for example, a three-pole one where the tower will not detect it ;)
  • #7 16862746
    sylweksylwina
    Help: 1882
    Rate: 2355
    What three-field? TRS? After all, this tower has a 2x China entrance.
    Unless the author connects via a cable to the headphone output of the tower :)
    DejoDejo
    Help: 35
    Rate: 75
    I wrote that he would show what he connected ;)
  • #9 16862829
    Darkevooo
    This cable which is connected connect it to the phone
    • Technics SH-EH750: Connecting a Phone, Aux Input Settings & Playing Music through Towers image.jpg (997 KB) You must be logged in to download this attachment.
    sylweksylwina
    Help: 1882
    Rate: 2355
    It's a headphone output, you have AUX on the back!
  • #11 16862853
    Darkevooo
    This is what I have to set up so that I can hear the sound in the tower settings
  • #12 16862856
    sylweksylwina
    Help: 1882
    Rate: 2355
    Connect to a good entrance.
    DejoDejo
    Help: 35
    Rate: 75
    You have to distinguish between entry / exit, a colleague above tells you well. Use this kind of cable for this:
  • #14 16862875
    Darkevooo
    What is the name of this cable and where can it be bought
    Added after 6 [minutes]:
    So I won't be able to connect the tower via this cable what I have
    sylweksylwina
    Help: 1882
    Rate: 2355
    You can even use google graphics to "search by image". This is a jack 2x chinch cable.
    Next time it's better to think a little, take a look at the user manual, etc. It is rather all generally available on the Internet. For sure, if you had a bit of a desire, then you would have come to what and how ... unless you connect two jack phones ...
    Edit: you won't connect
  • #16 16862914
    Darkevooo
    I thought it would give you towers + telephone with this cable connect ... good thanks for your help
  • #17 16863173
    DejoDejo
    Help: 35
    Rate: 75
    I already wrote to you - you need to distinguish between input / output:
    - By connecting headphones to the phone, the sound goes from the phone to the headphones meaning you have "output / OUT"
    - By connecting headphones to the headphone jack in the tower the sound goes from the tower to the headphones so you also have "output / OUT"
    - You tried, or rather connected the output to the output and hence the result
    - At the back of the tower you have "IN" sockets, i.e. input, so the correct solution is to connect a telephone with the "output" socket to the "input" socket (the music comes out of the phone and enters the tower)
    I can't do it simply ;)
  • #18 16871129
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Darkevooo wrote:
    what is the name of this cable and where can it be bought
    Minijack - 2 chinches, you can buy it in any electronics store.
    DejoDejo wrote:
    At the back of the tower you have "IN" sockets, i.e. inputs, so connecting the phone with the socket is the correct solution
    With this cable, what you buy - a mini jack for the phone, 2 chines from the REAR to the tower, choose the AUX input on the tower remote.
The discussion revolves around connecting a phone to the Technics SH-EH750 tower via an AUX input. The user initially struggles to hear music from the phone through the tower despite connecting it. Responses suggest changing the audio source to AUX and ensuring the correct cable is used. It is emphasized that the phone's output must connect to the tower's input, and a specific type of cable, a minijack to dual RCA (chinches), is recommended for proper connectivity. Users are advised to check the functionality of the cable and the correct ports on both devices to resolve the issue.
TL;DR: Fix no-sound by a 3-step setup using 1 cable: “connect the phone’s output to the tower’s input.” Select AUX and play. [Elektroda, DejoDejo, post #16863173]
Why it matters: This FAQ helps Technics SH-EH750 owners quickly connect a phone to AUX and troubleshoot silent playback.
How do I connect my phone to a Technics SH‑EH750 and get sound?
Use a 3.5 mm to 2×RCA cable. 1) Plug 3.5 mm into the phone. 2) Plug RCA L/R into the rear AUX IN. 3) Select AUX on the Technics and press Play on the phone. [Elektroda, KOCUREK1970, post #16871129]
Which exact cable do I need and what is it called?
You need a “mini‑jack to 2 chinches” (3.5 mm TRS male to 2×RCA male) stereo audio cable. Ask for “3.5 mm to RCA L/R.” [Elektroda, sylweksylwina, post #16862903]
I switched the source to AUX but still hear nothing—what should I check?
Confirm the cable works and the phone’s headphone output is active using a headphone test. Re-seat plugs firmly. [Elektroda, sylweksylwina, post #16862741]
Can I use the tower’s front headphone jack as an input?
No. The headphone jack is an output. “Output to output” connections do not pass audio to speakers. [Elektroda, DejoDejo, post #16863173]
Will a headset (TRRS) cable from my phone work in AUX?
Headset TRRS plugs can misalign contacts and fail. Use a plain stereo TRS lead for reliable line output. [Elektroda, DejoDejo, post #16862745]
How do I change the input to AUX on the Technics SH‑EH750?
After wiring, press INPUT/SELECT on the unit or remote and choose AUX. Then start playback on the phone. [Elektroda, KOCUREK1970, post #16871129]
Why do I hear music on my phone but nothing from the speakers?
You likely connected to the tower’s headphone output or the wrong input. Route phone OUT to tower IN. [Elektroda, DejoDejo, post #16863173]
