How to connect Technics sh-ge70 graphic equalizer with su-vz320 amplifier?
Thank you in advance for your answer.
antek124 wrote:You connect the amplifier output from 'rec out' to the equalizer 'in' and the 'out' output from the equalizer to 'play in' in the amplifier and it should work.
jakubs2213 wrote:antek124 wrote:You connect the amplifier output from 'rec out' to the equalizer 'in' and the 'out' output from the equalizer to 'play in' in the amplifier and it should work.
Did not work.
