Connecting Samsung TV K5500 Series 5 to Technics SU-808 Amplifier Using 3.5mm Jack
Rafasia 5070 8
  • #1 16465889
    Rafasia
    I have a question:
    Is it possible to come out with sound from Samsung TV K5500 Series 5 on the amplifier Technics SU-808 ?
    I have purchased something such , but after connecting via 3.5mm jack cable -> cinch unfortunately does not work. I will be grateful for your help.
    Raphael
  • #2 16465905
    Piotr2608
    Help: 851
    Rate: 4487
    He quotes:
    "Are you wondering if the adapter will work with your device? Answer the following questions:
    Does the device have an optical output / input?
    Is the cable to which we connect the adapter an optical cable?
    By connecting the adapter to an analog cable with JACK 3.5 plug you will not get any effect. "
    What kind of cable did you finally connect it?
    ZimTech Piotr Zimny
  • #3 16465914
    Rafasia
    I connected it using a 3.5mm jack -> cinch cable.
    I also read this description (although I found this page after the fact) and I do not understand it too much, because the adapter has a JACK 3.5 output .... what is it for ??
    Adam-T
    Help: 834
    Rate: 1096
    What you bought is an optical connector adapter (to an optical connector), simply speaking, a fiber optic connector. And you connected an ordinary "wire" to it. As you noticed, it won't work like that.
    The "wires" have different plugs, eg small, large, cinch, DIN, etc. jacks. The same optical fiber can have different plugs.
  • #5 16465966
    Rafasia
    Ok, I just watched it carefully ......: / Thank you for the clarification :)
    Does anyone have a mistake as to how to easily connect it? Probably some converter etc .....
    arturdip
    Help: 170
    Rate: 324
    The TV has an optical output, so a cable on one side an optical input on the other RCA (-cinch). About PLN 70 in the store.
    RCA in e.g. cd or aux in the amplifier
  • #7 16466149
    Rafasia
    Artur, I will be grateful for a specific link, I just don't want to buy something wrong a second time, thanks.
    arturdip
    Help: 170
    Rate: 324
    For example, on the well-known portal optical-coaxial-to-stereo-converter-power-usb-i6015669841.html.
  • #9 16466214
    Rafasia
    Thank you very much for help :)
The discussion revolves around connecting a Samsung TV K5500 Series 5 to a Technics SU-808 amplifier using a 3.5mm jack to RCA (cinch) cable. The user initially attempted this connection but encountered issues with sound output. Responses clarified that the TV has an optical output, and the user mistakenly used an optical connector adapter with an analog cable, which is incompatible. A solution was suggested to use an optical cable from the TV's optical output to an RCA input on the amplifier, with a recommendation to purchase an optical-to-RCA converter for proper connectivity.
