Audi A6 C6 - Rear Wiper Constantly Active: Ignition Impact and Relay Query
kanar2306 10674 5
  • #1 16863090
    kanar2306
    Help: 23
    Rate: 283
    I warmly welcome....
    I have such a little problem with the rear wiper. It works all the time after turning on the ignition. I know that the topic has already been discussed, but I wanted to find out how the wiper is controlled. It has +12 on the plug and three masses all the time, no matter how the lever is set ... Is there a relay for this ??
  • #2 16863166
  • #3 16863217
    kanar2306
    Help: 23
    Rate: 283
    Can you ask for a hint where is this relay? I looked next to the lamp but you can't see anything .. In the measuring blocks 16, channel 2 everything shows well, i.e. the lever is ok ... but where is the relay ??
  • #4 16869404
    kanar2306
    Help: 23
    Rate: 283
    Hello ... I will add that the handle is ok because the values change in the measuring blocks ...
  • Rear lamp module contains wiper timing electronics
    #5 16869979
  • #6 16878603
    kanar2306
    Help: 23
    Rate: 283
    The electronics in the motor itself turned out to be the culprit ...
