Panasonic TX-65EX600E: Image Mirroring Problem with Samsung NP370R5E Laptop & Win10
bubik75 8109 7
  • #1 16867542
    bubik75
    I have a Panasonic TX-65EX600E tv and a samsung laptop np370r5e unfortunately you can not duplicate the laptop screen on tv. According to the specification, the laptop supports miracast. I have win 10 updated to the latest version. The laptop and tv are interconnected and after 2 seconds the connection is broken. I will only add that I checked it on 4 laptops and the problem is exactly the same. I managed to duplicate the image on a laptop with win 8.1 but after disconnection it unfortunately behaves like the others. The Samsung service sends me to Microsoft to panasonic and the wheel closes the only hope in you. Thank you very much for your interest and help.
  • #2 16868127
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    Nowhere on the Samsung website have I found information that this laptop supports miracast, the TV allows streaming television to the internet enabling watching TV via the internet on your phone or tablet.
  • #3 16868437
    bubik75
    WEDŁUG WSZELAKICH PRAWIDEŁ I TEMU CO POKAZUJE SYSTEM POWINNO TO DZIAŁAĆ
    PRZYNAJMNIEJ TYLE ODPOWIEDZIELI MI W MICROSOFCIE
    I NA TYM ICH POMOC SIĘ ZAKONCZYŁA:) TZ UZYSKAŁEM INFORMACJE ZE JEZELI OSTATNI WIERSZ POSIADA WSZYSTKIE OPCJE JAKO "YES" TO NIE MA BATA MUSI DZIAŁAC.
    Microsoft Windows [Version 10.0.16299.98]
    (c) 2017 Microsoft Corporation. Wszelkie prawa zastrzeżone.
    C:\Users\Samsung>Netsh WLAN show drivers
    Interface name: Wi-Fi
    Driver : Intel(R) Centrino(R) Advanced-N 6235
    Vendor : Intel Corporation
    Provider : Intel
    Date : 2015-04-30
    Version : 15.18.0.1
    INF file : oem13.inf
    Type : Native Wi-Fi Driver
    Radio types supported : 802.11a 802.11b 802.11g 802.11n
    FIPS 140-2 mode supported : Yes
    802.11w Management Frame Protection supported : Yes
    Hosted network supported : Yes
    Authentication and cipher supported in infrastructure mode:
    Open None
    Open WEP-40bit
    Open WEP-104bit
    Open WEP
    WPA-Enterprise TKIP
    WPA-Enterprise CCMP
    WPA-Personal TKIP
    WPA-Personal CCMP
    WPA2-Enterprise TKIP
    WPA2-Enterprise CCMP
    WPA2-Personal TKIP
    WPA2-Personal CCMP
    Open Vendor defined
    Authentication and cipher supported in ad-hoc mode:
    Open None
    Open WEP-40bit
    Open WEP-104bit
    Open WEP
    WPA2-Personal CCMP
    Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
    Przepraszam za duże litery:)
    Tak samo dxdiag pokazuje:
    Time of this report: 11/29/2017, 13:27:53
    Machine name: SAMSUNG-PC
    Machine Id: {41FE2995-7924-43C1-B8E0-893496503EE8}
    Operating System: Windows 10 Home 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534)
    Language: Polish (Regional Setting: Polish)
    System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
    System Model: 3570R/370R/470R/450R/510R/4450RV
    BIOS: P15RAN.208.140429.ZW
    Processor: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
    Memory: 4096MB RAM
    Available OS Memory: 3982MB RAM
    Page File: 3285MB used, 2871MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 12
    DX Setup Parameters: Not found
    User DPI Setting: 96 DPI (100 percent)
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    Miracast: Available, with HDCP
    Microsoft Graphics Hybrid: Supported
    DxDiag Version: 10.00.16299.0015 64bit Unicode
    DxDiag Notes
    Display Tab 1: No problems found.
    Display Tab 2: No problems found.
    Sound Tab 1: No problems found.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: Intel(R) HD Graphics 4000
    Manufacturer: Intel Corporation
    Chip type: Intel(R) HD Graphics Family
    DAC type: Internal
    Device Type: Full Device
    Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_C706144D&REV_09
    Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
    Device Problem Code: No Problem
    Driver Problem Code: Unknown
    Display Memory: 1792 MB
    Dedicated Memory: 32 MB
    Shared Memory: 1760 MB
    Current Mode: 1366 x 768 (32 bit) (60Hz)
    HDR Support: Not Supported
    Display Topology: Internal
    Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
    Color Primaries: Red(0.590344,0.340344), Green(0.330578,0.550305), Blue(0.150891,0.140148), White Point(0.313977,0.329602)
    Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
    Monitor Name: Generic PnP Monitor
    Monitor Model: unknown
    Monitor Id: AUO46EC
    Native Mode: 1366 x 768(p) (59.982Hz)
    Output Type: Internal
    Monitor Advanced Color Capabilities: None
    Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
    Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll
    Driver File Version: 10.18.0010.4358 (English)
    Driver Version: 10.18.10.4358
    DDI Version: 11.2
    Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
    Driver Model: WDDM 1.3
    Graphics Preemption: DMA
    Compute Preemption: Thread group
    Miracast: Supported
    Laptop działa na 8.1 na 10 niestety nie dubluje a nie chciałbym wracac do 8.1 z powodu dublowania:)
  • #4 16886569
    Balon14
    Rate: 12
    I have the same TV and tablet with Windows 10 the latest version of the system, from time to time mirroring somewhere about 1 to 50 mirroring attempts? Later, for the mirroring to work again, I need to remove the panasonic display in Windows. I don't know what it is but in my opinion the fault is in Windows 10 because e.g. phones with android connect straight away.
  • #5 16912814
    lthom2
    I have the same problem. I have Panasonic VIERA_txcx740e and for China folk do not want to keep the laptop connection on windows 10 ... With the tablet galaxy tab 4 there is no problem. Does anyone have any idea where to bury to fix it?
    Greetings!
  • #6 16964283
    lthom2
    I do not know how for whom but for myself I found a solution to get a miracast connection from a laptop win 10 on the TV screen ...
    Click on "start" or there the windows badge> enter settings> enter privacy> find and enter the "Radio devices" tab> and the "Allow applications to control radio devices" function is marked as "ON". The application that is to control the radio devices is "Windows" and we mark it as enabled.
    It worked for me. Let me know how you are.
    Greetings!
    • Panasonic TX-65EX600E: Image Mirroring Problem with Samsung NP370R5E Laptop & Win10 ustawienia.png (90.88 KB) You must be logged in to download this attachment.
  • #7 16964898
    Balon14
    Rate: 12
    @ lthom2
    Even that helped, the tv connects to the computer, but not always, I have to wait a few minutes for one to connect the TV with the computer again, but it works, thanks for the information, best regards.
  • #8 16965179
    lthom2
    Well, I will not say that it works perfectly but it works :-) Sometimes when I play a movie there are visual disturbances and something "ticks" on TV, but after restarting the laptop it works again.
    It's nice that someone managed to help ;-)
The discussion revolves around the issue of mirroring the screen of a Samsung NP370R5E laptop to a Panasonic TX-65EX600E TV using Miracast on Windows 10. Users report that despite the laptop's specifications indicating Miracast support, the connection fails after a few seconds. Some users have successfully mirrored their screens using Windows 8.1, but encounter similar disconnection issues. Suggestions include checking Windows settings related to radio devices and ensuring that the "Allow applications to control radio devices" option is enabled. While some users have found intermittent success with these adjustments, others continue to experience problems, indicating a potential compatibility issue with Windows 10.
