LG UJ635V TV: Screen Share Connection Failure with Acer Predator 17 Laptop via Miracast
skylfer1 7518 2
  • #1 17016277
    skylfer1
    About a month ago I purchased an LG UJ635V TV. Among other things, I was tempted by the Screen Share function, so that I did not have to connect the laptop to the TV via a cable, but from the very beginning I have problems with connecting. I have two laptops, both support miracast, but neither of them can establish a connection. Screen Share from the phone works fine. Laptop sees the TV after all, when you try to connect, after about 3-5 seconds, the message "device failed" pops up, and "device disconnected" appears on the TV. The same thing happens when using Wi-Fi Direct, but it takes a little longer.
    Laptop - Acer Predator 17
    Internet - Vectra.
  • #2 17027844
    michald
    Help: 210
    Rate: 437
    Was there an attempt to connect the laptop to another tv in this configuration?
  • #3 17029635
    skylfer1
    Unfortunately, I do not have such a possibility. I was wondering if there are any specific settings that would allow the connection, but I don't know anything about it. I have two laptops at home and both have the same problem.
