Audi Q7 3.0TDI Fails to Start After Battery Replacement: Steering Angle Sensor Error
suchutki 23253 19
How do I get an Audi Q7 3.0 TDI to start again after a battery replacement when a steering angle sensor / voltage fault appears?
You should first code/adapt the replacement battery, then check the engine start permission in the measuring blocks if it still does not start [#16868215][#16868853] The thread later showed that the engine was cranking too slowly at first, with only 126–140 rpm and 0 bar rail pressure, and another reply noted that these engines usually need over 200 rpm to fire [#16874726][#16874969] The next advice was to check the low-pressure supply from the tank because a weak in-tank pump can feed but still be too weak to supply the CR pump, and to verify whether there is any fuel pressure at the rail during cranking [#16875099][#16879436] After both tank pumps were checked and reported OK, suspicion moved to the fuel metering valve on the CR pump because no fuel was coming out on the high-pressure side during starting [#16878966][#16886748] A later follow-up also suggested clearing start-permission faults and checking whether the steering wheel is unlocked [#20845184]
  • #1 16868189
    suchutki
    Rate: 10
    Hello, help please, I have a problem with the audi q7 3.0TDI after replacing the battery (the old one has discharged a maximum), the car does not start even with cables from the second car. After diagnostics, there are no errors in the engine controller, only what came out is the steering angle sensor sensor error - terminal voltage + 30, oil pressure sensor damage - short circuit to plus, I ask for help although I read on the forum that someone had the same problem and solved it but the topic was closed without an answer. I will add that after charging the battery and installing it in the car it shows a 10% charge, please suggestions where to look for the problem. Regards and hints for some hints
  • #2 16868215
    sk700
    Help: 173
    Rate: 420
    Replacement of the battery must be encoded in this car, if it still does not want to start it would suit to check whether there is permission to start the engine ...
  • #3 16868434
    suchutki
    Rate: 10
    sk700 thanks for the hint buy a new battery for sure and I will try to code
    sk 700 and it is normal that it shows a 10% charge
    how how to check if there is permission to start the engine
  • #4 16868853
    sk700
    Help: 173
    Rate: 420
    In measuring blocks, but code a new battery first.
  • #5 16870069
    suchutki
    Rate: 10
    sk 700 thanks for the info tomorrow I will collect the battery and I will code and then we will see what will happen despite everything thanks to you ladies for hints I will answer and let you know
  • #6 16870228
    jkm73
    Help: 32
    Rate: 173
    Without coding, it should light up, if you did not mistake the clamp ... Or just the battery sucks, or maybe the weight on the right side member :) .
  • #7 16872234
    suchutki
    Rate: 10
    jkm73 thanks for the hints but the mass on the side member of the engine I checked for contact and corrosion everything is ok
    Added after 14 [minutes]:
    , the old battery I checked and came out that it has 65% efficiency, juro, I will insert a new one and encode and see, but if you have any ideas on what to pay attention to, please give hints and thank you very much
  • #8 16874726
    suchutki
    Rate: 10
    I bought a new battery and turns without clutching, but the car still doesn't smoke, so I checked the engine speed during the turn and came out in the range of 126 to 140 rpm (invisible or sometimes it should not be 250), I also checked the pressure in the ramp and it is 00 bar. does anyone know what's going on because there are no mistakes
  • #9 16874850
    sk700
    Help: 173
    Rate: 420
    Disconnect the flow and see if it throws an error.
    Give autoscana so we know what we're talking about.
    Is the cake good?
  • #10 16874969
    robi1214
    Help: 151
    Rate: 869
    Engine speed too low.
    There will be over 200 that will light up.
  • #11 16875099
    sk700
    Help: 173
    Rate: 420
    Without pressure on the strip it won't get far, even if now somehow there is no pressure error, after farting on the cake must catch it. Unless the controller has garage engine bloom.
    Rotation sensors might be freaking out but then there should be a synchronization error.
    Someone more experienced must confirm this but these engines had about 140 revolutions on the starter.
    Give autoscana because we don't even know what engine code we're talking about.
  • #12 16876615
    suchutki
    Rate: 10
    SK 700 also doesn't smoke, I don't want to catch it, but unfortunately it doesn't start
    Added after 4 [minutes]:
    gentlemen, just a moment ago I connected a computer under the same engine and Ania while turning it was 196 revolutions and 320 bar pressure, if the pressure sensor on the rail flew at me and he does not give the command to open the injectors or it is open and turning the starter I can not put pressure on it you think
    sk 700 engine code BUG 171 KW 3.0 TDI
  • #13 16877351
    sk700
    Help: 173
    Rate: 420
    There may be a pressure problem, but why not catch a low pressure error? Unplug this sensor and check if it fires and if it catches its error because you may have been ecused. I wonder that he doesn't even get it. Maybe it's worth taking a look what's happening in the inlet?
  • Suspected fuel metering valve fault on CR pump
    #14 16878966
    suchutki
    Rate: 10
    hello I was just embracing the car and it turns out that there is a problem with the fuel on the high pressure ramp after unscrewing one of the fuel feed lines to the injection it turns out that no fuel leaks during start-up (there is no pressure even the fuel does not leak). the first suspicion fell on the fuel pump in tank, however, the pump feeds the filter fuel from the filter chasing through the fuel temperature sensor to the CR pump and here I think there is a problem because there is a fuel dispensing valve on the side of the pump (I don't know how to check it works, I can connect the meter and check if it comes to voltage) the problem is that there are three wires in it and I do not know where to connect so that something does not screw up. All those who know the topic of cr pump please help, maybe someone will give an idea how to go about it, greetings and please help
  • #15 16879436
    sk700
    Help: 173
    Rate: 420
    Start by measuring the pressure of the pump in the tank, they fell so that they pumped but under too low pressure and were unable to power the CR pump. Ew, hook up another one for a trial.
  • #16 16881850
    suchutki
    Rate: 10
    from what orjeje, there are two pumps in the tank tomorrow I will be tearing, so let me know
  • #17 16886748
    suchutki
    Rate: 10
    hello it turned out that there are two pumps in the tank today I checked them everything with them ok they give the right amount of fuel according to the service, my suspicion fell on the fuel dispensing valve at the CR pump and someone knows how to check it
  • #18 20845153
    cobr484
    I have the same problem. Can you write how you solved the problem and what happened?
  • #19 20845184
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Clear the errors - especially in the take-off permission and it should start. Are your lights on? Is the steering wheel unlocked????
  • #20 21433961
    filipCrypton
    I am writing with the same problem car does not start no pressure on the rail 0 bar when spinning. Replaced CR pump and all sensors on the strip. Does anyone know the solution?
An Audi Q7 3.0 TDI (engine code BUG, 171 kW) fails to start after battery replacement. The new battery shows only 10% charge initially and requires coding in the vehicle's system. Diagnostics reveal no engine controller errors except steering angle sensor voltage issues and oil pressure sensor short circuit. The engine cranks at low RPM (126-196 rpm) but does not start or build fuel rail pressure (0 bar). Fuel does not leak from the high-pressure rail during cranking, indicating no fuel delivery. The fuel supply system includes two in-tank pumps feeding the common rail (CR) pump. Both tank pumps tested OK, shifting suspicion to the fuel dispensing valve on the CR pump, which has three wires and unclear testing procedure. Suggestions include verifying start permission coding, checking mass connections, unplugging the fuel pressure sensor to detect errors, and measuring tank pump pressure. Similar cases report clearing errors related to start permission and steering lock status. Replacement of the CR pump and rail sensors was attempted without success. The problem likely involves fuel delivery or control issues at the CR pump or related sensors.
TL;DR: Q7 3.0 TDI no‑start after battery swap? Target 200 rpm cranking; “There will be over 200 that will light up.” [Elektroda, robi1214, post #16874969]
Why it matters: This FAQ helps Audi Q7 3.0 TDI owners quickly isolate post‑battery‑replacement no‑start causes and restore reliable starts.
Why won’t my Audi Q7 3.0 TDI start right after I changed the battery?
Battery coding/registration can be required, and start authorization should be verified. Low cranking speed or zero rail pressure also prevents starting. Begin by registering the battery, then read live data for rpm and rail pressure while cranking. Clear related faults and retest. [Elektroda, sk700, post #16868215]
Do I really need to code/register the new battery on a Q7?
Yes—owners and techs advise coding the replacement before deeper diagnostics. It ensures proper energy management readings. Expert tip: “code a new battery first.” Perform this with VCDS/ODIS under battery adaptation, then retest starting. [Elektroda, sk700, post #16868853]
What cranking speed should I see for the 3.0 TDI to fire?
Aim for about 200 rpm or higher during crank. A community expert notes, “There will be over 200 that will light up.” If your scan shows well under this, charge the battery, check grounds, and verify starter performance. [Elektroda, robi1214, post #16874969]
How much rail pressure should I expect while cranking?
A working reference showed ~320 bar at about 196 rpm. Zero bar indicates a supply or control problem. If you read 0 bar, verify in‑tank pump delivery, filter condition, and the CR pump’s metering/rail sensor operation. [Elektroda, suchutki, post #16876615]
How do I check if start authorization is blocking the crank or start?
Scan for start‑permission faults and clear them. Confirm the steering unlocks and lights behave normally. Then attempt a start and recheck fault memory. If authorization returns, address immobilizer/column lock issues before fuel/air diagnostics. [Elektroda, sadek1979, post #20845184]
How can I test the in‑tank fuel pumps on this Q7?
Measure delivery pressure and volume, not just pump noise. Some pumps spin yet produce too little pressure to feed the CR pump. Substitute a known‑good pump or bench‑test pressure to confirm supply under load. This edge case is common. [Elektroda, sk700, post #16879436]
Does this Q7 have one or two fuel pumps in the tank?
Owners reported two pumps in the tank on this platform. Inspect both sides of the saddle tank and verify electrical supply and output from each unit when diagnosing no‑rail‑pressure situations. [Elektroda, suchutki, post #16881850]
How do I verify the rail pressure sensor or the CR pump’s metering valve?
As a quick test, unplug the rail pressure sensor and attempt a start. The ECU should log a related fault; behavior helps directionally diagnose sensor or wiring issues. Inspect intake and air path if it still won’t catch. [Elektroda, sk700, post #16877351]
My scan shows no engine DTCs, yet it still won’t start. What should I try next?
Disconnect the MAF (airflow) to provoke a fault and observe changes. Provide a full autoscan so helpers know the exact controller set and engine code. Also confirm fuel quality (“cake”) and basic mechanical health. [Elektroda, sk700, post #16874850]
What are “measuring blocks,” and how do they help here?
Measuring blocks are live data groups in VCDS/ODIS. Use them to read cranking rpm, start authorization status, and rail pressure while testing. Always code the new battery first, then compare readings to known‑good values. [Elektroda, sk700, post #16868853]
VCDS shows only 10% battery charge right after charging. Is that normal?
One poster observed 10% SOC after charging. Low indicated SOC can follow battery replacement until coding and adaptations settle. Register the battery, clear faults, then re‑evaluate SOC and starting behavior. [Elektroda, suchutki, post #16868434]
How do I run a fast 3‑step no‑start checklist on the 3.0 TDI?
  1. Register the new battery and clear faults.
  2. Read measuring blocks for cranking rpm and rail pressure.
  3. Measure in‑tank pump pressure/volume or swap in a known‑good unit.
    “Supply pressure too low will not feed the CR pump.” [Elektroda, sk700, post #16879436]
Starter turns but rail pressure stays at 0 bar—what’s the next move?
Confirm both saddle‑tank pumps deliver proper pressure to the filter and high‑pressure pump. A weak supply pump can spin yet starve the CR pump. Test under load or substitute a known‑good unit before replacing sensors. [Elektroda, sk700, post #16879436]
Could a control unit fault cause a no‑start even with fuel and rpm present?
Yes, an ECU issue is an outside possibility. One member flagged this as a rare edge case after other causes are excluded. Verify synchronization faults and basics first to avoid misdiagnosis. [Elektroda, sk700, post #16875099]
