Pairing Ministry of Sound Bluetooth Headphones with LOGIK L32SBT17 2.0 Soundbar Issue
Messs23 8205 9
How can I connect Ministry of Sound Bluetooth headphones to a LOGIK L32SBT17 soundbar and TV setup?
You cannot pair the headphones directly to the soundbar; Bluetooth needs a sender/host and in this setup both the soundbar and the headphones are receivers, so the headphones should pair with the source device instead [#16871154][#16872240] The source here is the TV, so check whether the TV has Bluetooth in its technical specifications/manual; if it does, pair the headphones to the TV, not to the soundbar [#16873206][#16873484][#16873611] In this case the TV model mentioned does not appear to have built-in Bluetooth, but it does have a headphone jack output [#16873611] The practical options are to use headphones with a cable, or buy a Bluetooth transmitter for the TV and connect the current headphones to that transmitter [#16873611]
  • #1 16871060
    Messs23
    I would like to pair the Ministry of Sound bluetooth headphones with the LOGIK L32SBT17 2.0 soundbar. The soundbar works fine and is well connected. The soundbar and headphones in pairing mode do not connect, I do not know where I can find the cause.
  • #2 16871154
    JacekCz
    Help: 760
    Rate: 1464
    that you need to connect to the source, the so-called host?
    BT is not a connection between everyone who wants to se and with everyone, but a specific device profile for a specific purpose
  • #3 16871253
    Messs23
    The headphones should work together in this connection. Anyone have other suggestions and an idea how to combine it step by step?
  • #4 16872240
    Polon_us
    Help: 1184
    Rate: 1282
    JacekCZ's colleague is right.
    There is no point in connecting headphones to the sound-bar.
    There must be a sender and receiver relationship.
    The sound-bar and headphones are just receivers.
  • #5 16872595
    Messs23
    So there is nothing I can do in this situation? There is no solution?
  • #6 16873206
    Polon_us
    Help: 1184
    Rate: 1282
    To connect to the sound bar?
    I have already spoken.
    Have a colleague explain to which device the sound bar is connected.
    Maybe this device will be able to connect to the headphones.
  • #7 16873470
    Messs23
    The soundbar is connected to a tv without Bluetooth. I forgot to mention tv ... :-)
    Polon_us
    Help: 1184
    Rate: 1282
    And the model of that TV set? heh ...
    After all, the TV can support BT, you need to check the specification.
    The headphones should pair with this device without any problems.
  • #9 16873504
    Messs23
    jvc tv 32inchc672
    Well, and how does this specification work? I don't know how to go about it. Thanks in advance for every hint :-)
    Polon_us
    Help: 1184
    Rate: 1282
    "Check specification" means otherwise check technical data.
    In this case of the TV, they are usually included in the instruction manual.
    As far as I can see, the TV does not have a BlueTooth feature built in.
    But it has an output (jack) for headphones.
    I would also suggest replacing the headphones with one with a traditional cable connection.
    You could also buy a BT transmitter and attach it to your TV.
    Then the current headphones could be used.
    The question is whether "the skin is worth a layette" ...
The discussion revolves around the difficulty of pairing Ministry of Sound Bluetooth headphones with the LOGIK L32SBT17 2.0 soundbar. Users highlight that Bluetooth connections require a specific sender-receiver relationship, and since the soundbar is connected to a non-Bluetooth TV (JVC 32inch C672), it cannot directly connect to the headphones. Suggestions include checking the TV's specifications for Bluetooth capability, using a wired connection, or purchasing a Bluetooth transmitter to enable the connection between the TV and the headphones.
