Connecting Bluetooth to LG 55LH615V-ZE TV: Troubleshooting HDMI Cable & Soundbar Issues
aro383 21687 3
  • Bluetooth audio options for LG 55LH615V-ZE TV
    #1 16971111
    aro383
    Rate: 9
    Hello, I have a TV LG model 55LH615V-ZE which does not have a bluetooth problem is that I have a sundbar connected to it now with a HDMI cable which does not look great because the TV hangs on the wall and only this one cable hangs under it so I have a question whether it is possible connected to a bluetooth TV which is getting fused with sundbara. I will add that I tried to use bluetooth for usb, but tv did not recognize it, probably because the TV has only usb in a must be probably out. I am asking for proven methods and not for speculation. Regards and thanks ...
  • #2 16971185
    mladenick
    Help: 14
    Rate: 90
    you need to buy a bluetooth transmitter with a jack, connect a transmitter to USB (only to power the transmitter) and plug the jack into the socket of TV headphones and then pair the devices
  • #3 16975421
    aro383
    Rate: 9
    mladenick thanks for resp. after reading your answer I ordered a bluetooth but after thinking I came to the conclusion that I made a mistake because now that I turn on the sundbara automatically mute me tv and the way that you describe I will have to override in options every time it is no longer cool but thanks and I'm almost 40 zlotys in the back.
  • #4 16976364
    mladenick
    Help: 14
    Rate: 90
    I do not understand why saundbar, if you want to use it only sometimes, if you have saundbar, it works when the tv is on, at least I have it and I have no reason to change it,
    Well, 40 zlotys for the adapter, you overpaid a little, the one for 15 zlotys would do exactly the same job, send only the signal without changes.
