Activating Bluetooth Audio on Samsung UE58MU6122 TV: Service Menu Access Issues
betirazz 14259 14
How can I enable Bluetooth audio on a Samsung UE58MU6122 TV, and why can’t I get back into the service menu after changing BT-AUDIO ON?
You probably can’t enable Bluetooth audio on this model because Samsung support said the UE58MU6122 (and UE58MU6192) does not have Bluetooth hardware physically installed, so the menu option will not appear even after changing service-menu flags [#17592690] Instead, use the TV’s optical audio output and add an external converter/DAC if you want a headphone jack, or a Bluetooth audio receiver/transmitter if you want wireless headphones [#17593491][#17594919] One suggested fix for the service menu issue was to restore factory settings and then try the info-menu-mute-power sequence again [#17594464] In the end, the practical solution reported was an optical-output converter: TV sound could be heard from both the TV and headphones, and the user switched to optical on the TV when watching TV to avoid echo from the set-top-box speakers [#17613999]
  • #1 17590888
    betirazz
    Rate: 9
    Hello, I have the UE58MU6122 tv. Before the purchase, I was assured in a chat with a Samsung employee that it would be possible to connect speakers or headphones via bluetooth. Unfortunately, this is not possible on the menu of my tv. I read that the bluetooth option is often turned off in the service menu. So I entered the service menu (info-menu-mute-power) and selected BT-AUDIO ON in the settings. I turned the tv off and on, but still no headphone audio option. I read that more things need to be activated in the service menu (BT support - ON, Voice recognition - ON, Samsung Smart Control - ON, BT_AUDIO_ON_OFF - ON). I wanted to enter the service menu again, unfortunately it does not turn on. I turn off the TV, press the info-menu-mute-power key combination and nothing. The TV turns on but no service menu. Any advice?
  • #2 17591272
    stuart18
    Rate: 10
    How will you enter the menu -> sound -> speaker list, you do not have bluetooth there?
  • #3 17592690
    betirazz
    Rate: 9
    Exactly, there isn't. There are only 2 types of output: TV and audio optical.
    I can't re-enter the service menu - I don't know what could be the reason :(
    Ps I will add that in the morning in the samsung chat I got info that neither the 6122 nor the 6192 model have bluetooth physically. The Lord was unable to answer any question: neither why was I made a mistake with the purchase, nor how should I connect my headphones now.
    How does this blutooth not work, what is the possibility of connecting headphones to this tv? (So that there is sound from TV and headphones). What kind of headphones, what to buy. I have a video highway decoder connected to the TV. Speakers connected to the decoder (output from the decoder cuts white and red). For smart services (apps), I use TV speakers.
  • #4 17592850
    stuart18
    Rate: 10
    Check if you have sound output on TV. It should be labeled AUDIO OUT (two chinchas) on the back of the TV. Or just upload a picture of all TV connectors and set-top box
  • #5 17593308
    betirazz
    Rate: 9
    Activating Bluetooth Audio on Samsung UE58MU6122 TV: Service Menu Access Issues This is what it looks like from the back - all entrances. The HDMI cable is connected to a set-top box (highway), from where the sound is output to the loudspeakers via the chinch (white / red). The logitech keyboard transmitter sits in the usb.
    And this is what the TV sound menu looks like. I still can't enter the service menu - I don't know why the entry was blocked: /
    Activating Bluetooth Audio on Samsung UE58MU6122 TV: Service Menu Access Issues Activating Bluetooth Audio on Samsung UE58MU6122 TV: Service Menu Access Issues Activating Bluetooth Audio on Samsung UE58MU6122 TV: Service Menu Access Issues
  • #6 17593491
    stuart18
    Rate: 10
    You only have an optical audio output so you can try connecting the converter from Optical to RCA / Jack and then you can plug in your headphones.
  • #9 17594676
    betirazz
    Rate: 9
    And then I can connect e.g. radio headphones to this converter. I care about wireless headphones. I will try.
  • #11 17595095
    betirazz
    Rate: 9
    Cool too. The question is whether how to connect it with an optical cable, the sound will only be on the headphones or also on the TV.
  • #12 17595282
    stuart18
    Rate: 10
    The sound should be heard through the speakers and the headphones. Unless you switch to opt. Then it will only be in headphones
  • #13 17597311
    betirazz
    Rate: 9
    Well, it will only be on headphones .... no sense.
    Added after 29 [minutes]:
    Okay different. I have a tv (as above) and a decoder with hdmi and 2x rca output. Is it possible to connect a speaker / soundbar so that there is a voice on it from both the decoder and the TV (when using smart) with the possibility of connecting headphones (without losing the voice from the speaker).
  • #14 17602193
    stuart18
    Rate: 10
    Well, you don't read with understanding.
  • #15 17613999
    betirazz
    Rate: 9
    I bought a converter - connected to the optical output. The sound at TV set-up can be heard from both the TV and headphones :) When watching TV, I switch to optical so that there is no reverberation from the speakers connected to the decoder.
    To amplify the sound on the headphones, connected to the tower with an AUX output - this makes it louder to hear.
    thank you
The discussion revolves around the Samsung UE58MU6122 TV and issues related to activating Bluetooth audio. The user initially believed Bluetooth connectivity was possible but found no option in the TV's menu. Attempts to access the service menu to enable Bluetooth settings were unsuccessful. Other users suggested checking the sound output options and using an optical to RCA/jack converter to connect headphones. The user later confirmed successful audio output through both the TV and headphones using a converter connected to the optical output. The conversation also touched on the possibility of connecting Bluetooth headphones via an audio adapter, with discussions on maintaining sound from both the TV and external speakers.
TL;DR: For Samsung UE58MU6122 owners missing Bluetooth audio: the TV exposes 1 optical output; "You only have an optical audio output." Add an optical DAC and, if needed, a Bluetooth transmitter to use headphones. [Elektroda, stuart18, post #17593491]
Why it matters: It shows MU6122 users how to get headphone audio without unreliable service-menu tweaks.
How do I enable Bluetooth audio on a Samsung UE58MU6122?
You cannot enable Bluetooth audio in the standard menu on this model. Samsung support told the OP there is no physical Bluetooth. The Sound menu lists only two outputs: TV Speaker and Audio Optical. Use external audio solutions instead of software toggles. [Elektroda, betirazz, post #17592690]
Why can’t I re‑enter the service menu after turning BT options on?
Reset the TV to factory settings and try again. This often restores service‑menu access. As one helper advised, “Restore factory settings and then try to enter the service menu.” That step resolved similar access issues for users after changes. [Elektroda, stuart18, post #17594464]
Where would Bluetooth headphones appear in the menu if supported?
Check Menu > Sound > Speaker List. If your TV supported Bluetooth audio, that list would show Bluetooth devices there. If nothing appears, the feature is not present or enabled on your unit. [Elektroda, stuart18, post #17591272]
Does the UE58MU6122 have analog audio outputs for headphones?
No. This TV lacks analog RCA or 3.5 mm headphone outputs. It exposes only an optical SPDIF audio output on the rear panel. Use an optical DAC if you need analog audio. [Elektroda, stuart18, post #17593491]
What converter do I need to plug in wired headphones?
Use an optical‑to‑analog DAC that includes a dedicated headphone jack. Connect the TV’s optical output to the DAC, then plug in your headphones. The linked example in the thread specifically includes a headphone output for this purpose. [Elektroda, stuart18, post #17594464]
How can I add Bluetooth headphones to this TV?
Add a Bluetooth audio adapter/transmitter. Feed it with analog audio from an optical‑to‑analog DAC, since the TV only outputs optical. Then pair your Bluetooth headphones to the adapter. An aptX‑capable adapter can improve latency. [Elektroda, stuart18, post #17594919]
Will TV speakers and headphones work at the same time?
Yes, when the TV audio remains on TV Speaker. “The sound should be heard through the speakers and the headphones.” If you switch the TV output to Optical, audio routes to headphones only, muting the TV speakers. [Elektroda, stuart18, post #17595282]
Can I connect RF wireless headphones (with a base station)?
Yes. Use an optical‑to‑analog DAC that provides a headphone output. Connect the RF base station to that headphone jack. This approach works because the TV only exposes optical audio natively. [Elektroda, stuart18, post #17594464]
How do I prevent echo or reverb when both speakers and headphones play?
Switch the TV audio to Optical when needed. The OP reported echo from decoder speakers, then eliminated it by selecting Optical on the TV during TV viewing. That routes sound to the headphones only. [Elektroda, betirazz, post #17613999]
What’s the simplest 3‑step setup to add Bluetooth headphones?
  1. Connect the TV’s optical SPDIF to an optical‑to‑analog DAC.
  2. Connect the DAC’s analog output to a Bluetooth audio transmitter.
  3. Pair your Bluetooth headphones with the transmitter and set TV audio accordingly. [Elektroda, stuart18, post #17594919]
Can I route audio from both my HDMI decoder and TV apps to one setup?
Yes, but expect mode changes. The OP feeds decoder audio to external speakers via RCA and uses TV speakers for apps. That split works without extra gear. You can add an optical DAC for headphones from the TV path if desired. [Elektroda, betirazz, post #17593308]
Does toggling BT options in the service menu enable headphone audio on this model?
No. The OP turned BT‑AUDIO ON in the service menu, power‑cycled, and still saw no headphone audio option. Additional toggles did not help either. [Elektroda, betirazz, post #17590888]
What confirmed workaround finally worked for the OP?
They installed an optical DAC on the TV’s optical output. With TV audio set to TV Speaker, both the TV and headphones played. For TV viewing, switching to Optical avoided reverb. They also amplified headphone volume via a tower’s AUX. [Elektroda, betirazz, post #17613999]
