FM Transmitter Not Working: Repair Tips for Allegro Chinese Car Adapter, Screen Outage Issue
karol9919 21582 5
  • #1 16876904
    karol9919
    Rate: 9
    Hello. Well, I have an FM transmitter to play music on the car radio after connecting to the cigarette lighter. It is a cheap "Chinese" bought on allegro. After several times of use, the transmitter screen has gone out and has not been working since. What could be wrong? How to check and fix it? Right now I could use an old car and I have nothing to do. Someone could help? The device seems to be simple to build, but I don't know what I can do. Those willing to help could answer ;)
    Exactly the same as in the picture below:
  • #2 16876983
    sylweksylwina
    Help: 1882
    Rate: 2355
    Maybe put a picture of the center, we'll deduce something ... maybe.
  • #3 16877072
  • #4 16877084
    g107r
    Help: 811
    Rate: 993
    And sometimes there is no fuse in the input, as it has a lot of normal lighter plugs?
  • #5 16878659
    karol9919
    Rate: 9
    There is a fuse at the plug, but is it blown? How to check, and if so, what fuse will be good for this device (if it burned)?
  • #6 16878689
    g107r
    Help: 811
    Rate: 993
    And you can't see the wire in it?
    Connect a small light bulb to the battery through it, the light will come on - it's good.
    One of the smallest fuses, sure, up to 1A, which should be stamped / painted on it.
