Allegro-Purchased Chinese Car Radio: No Display or Power Upon Connection
Frodox 6831 10
Why does my Chinese car radio not turn on or show anything when connected?
Check the wiring first: make sure the ground is connected properly, and that you have not missed one of the +12 V leads [#16470535][#16470591] On the table test it with black to “-”, red to “+”, and yellow to “+” through its fuse; also verify the fuse on the yellow wire [#16470942] If everything is connected correctly and the fuse is good but it still stays dead, the radio is likely damaged [#16470595]
  • #1 16470532
    Frodox
    Car radio bought on the Allegro does not work when connected, does not display anything, you do not want to turn on the help, which may be wrong
    if necessary I can give a photo from the inside.
  • #2 16470535
    karolark
    Help: 702
    Rate: 2516
    show this connection especially ground :-)
  • #3 16470552
    Frodox
    the mass was connected to a battery, I would like to add that two other radios were on the same cube and they were not
  • #4 16470591
    gerdowski
    Help: 53
    Rate: 171
    Take a picture of the radio sticker with the lines drawn. I suspect you haven't connected one plus.
  • #5 16470595
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Damaged radio.
  • #6 16470615
    Frodox
    Allegro-Purchased Chinese Car Radio: No Display or Power Upon Connection \
    I rather connected the cables
  • #7 16470806
    WędkarzStoLica
    Help: 146
    Rate: 300
    You don't buy such inventions. Branded stimulant or new but also well-known brand even the cheapest and will be flying very long. Chinese car radios are making extremely crap and very emergency - we are talking about the cheaper ones, I don't know how the more expensive ones, but I wouldn't buy them anyway.
    If you want to have a great radio and you can't afford a new company one, buy a drug, never Chinese junk.
  • #8 16470942
    gerdowski
    Help: 53
    Rate: 171
    Plug in on the table, black "-", red "+", yellow with "+" fuse. Check the fuse on yellow.
  • #9 16472317
    Frodox
    I plugged in everything, the fuse is just good, I dump it, I will buy it used, but thanks for help
  • #10 16472379
    płetwa
    Help: 165
    Rate: 551
    People new radio in a normal store with a 2-year warranty of PLN 200!
  • #11 16581207
    Trochim867
    Even less than 200; P
A user reported that a car radio purchased from Allegro does not power on or display anything when connected. Responses suggested checking the ground connection and ensuring all power connections are correct, particularly the plus connections. Some users speculated that the radio might be damaged, while others advised against purchasing low-quality Chinese radios, recommending instead to buy from reputable brands with warranties. The user confirmed that the connections were made correctly and the fuse was intact, indicating a potential need to purchase a used radio instead.
