Peugeot Expert 2.0hdi 160km - 5ff internal fault bsi the wiper goes crazy
ct13 27984 4
  • #1 16882002
    ct13
    I need help with my peugot expert 2010, after turning off the screens, they get some impulse as if they want to start and it moves slightly.
    After connecting to the computer, an internal error bsi 5ff appears
    Thanks in advance for the hints
  • #2 16882463
    melas
    Help: 138
    Rate: 689
    Parameters you watched ?. Can you only read errors, check if the bsi sends a request for the wipers to work and then it is a commune to the bsm and from the bsm to the motor.
  • #3 16882656
    figus2
    Rate: 20
    Or maybe it is simply obliterated
  • #4 16883087
    ct13
    The wipers work, but when you turn them off, i.e. position 0, they still have an impulse and vibrate
  • #5 16883332
    dziesiaty1
    Rate: 37
    Hi!
    The wiper motor is probably not, but not for sure. I would take out the PSF and BSI, check for the presence of water, it will not hurt to dry it, after unplugging the connectors it is worth checking if it is green somewhere. Disconnect the battery 5 minutes before this operation and connect 5 minutes after. Internal BSI error may be related to the wipers but not necessarily, sometimes it is and everything works ok. Check if the error appears after turning on the wipers, because I understand that it can be deleted.
