Using Barracuda 7200.12 500GB HDD as External Disk: USB-SATA Adapter Options for 3.5 Drive
baszawez 12723 11
Can I power a 3.5-inch Barracuda 7200.12 HDD from USB with a simple USB-SATA adapter, or do I need an adapter/enclosure with a separate power supply?
No — a 3.5-inch drive needs 12V for the motor, so the simple USB-SATA adapter without 12V will not power it [#16884406][#16884524] The 5V line is used to power the drive’s electronics, not for data transfer, and the SATA power connector can also include an unused 3.3V line [#16884609] For a 3.5-inch HDD, use a case/pocket made for 3.5-inch drives with an external power supply, or a powered USB 3.0 dock/enclosure [#16885094][#16885096] A 2.5-inch USB enclosure is usually the wrong choice here and may not supply enough current even if it has a 5V-to-12V converter [#16884524]
  • #1 16884379
    baszawez
    Rate: 10
    I have an old Barracuda 7200.12 500GB HDD, I want to use it as an external disk. I thought about buying a USB-SATA adapter, on the Allegro I found something like this: http://allegro.pl/przejsciowka-adapter-usb-3-0-do-sata-dysk-hdd-ssd-i6748031418.html and such: http: //allegro.pl/adapter-usb-na-sata-ata-ide-2-5-3-5-led-zasilacz-i6189932472.html
    And here the question arises, this 1 is intended only for HDDs but 2.5 "while mine has 3.5". The number of pins is the same for both variants (7 + 15), but the question of power supply arises here. On my 3.5 "disk it says that the power supply is 5V and 12V while the 2.5" disk has only 5V power supply, is this adapter as in 1 link enough and I will power the hard disk via usb or it must be the one with 2 link with a separate power supply ? What does 5 and 12V power supply mean for a 2.5 "drive, can it be powered by 5V or 12V, or that 12V is intended for connecting the power supply and 5V for the SATA data plug?
  • #2 16884406
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    baszawez wrote:
    is it enough to use this adapter as in 1 link and power my hard disk via usb or does it have to be the one from 2 links with a separate power supply
    The second, in the first no 12v power supply
  • #3 16884524
  • #4 16884548
    baszawez
    Rate: 10
    So 12V in a 3.5´´ drive is used for power supply, and 5V for what? For data transfer?
  • #5 16884609
  • #6 16885081
    baszawez
    Rate: 10
    such a kit costs around PLN 25, I doubt that it would be more expensive than the disk pocket
  • #7 16885085
  • #8 16885094
    Plumpi
    Heating systems specialist
    Help: 874
    Rate: 2674
    There are ready enclosures for 3.5-inch drives with an external power supply in the form of a plug.
  • #9 16885096
    ORMO_PL
    Level 19  
    Help: 16
    Rate: 80
    My friend,
    The main idea of using external drives is that you can easily unplug them and move them to another computer.
    You have a nice disk, so I would suggest USB 3.0
    Such a more decent pocket will cost you a hundred,
    o, for example on the allegro: 7060818038
    By the way, was the ban on sending links to the auction lifted?
  • #10 16885107
  • #11 16885146
    djtommy
    Help: 38
    Rate: 41
    I don't recommend this adapter which you put in the second link. I bought something like that in Saturn and after the first connection the power supply burned. Fortunately, the disk did not suffer. A better option will be the pocket that ORMO_PL has sent.
  • #12 16885229
    baszawez
    Rate: 10
    in fact, I will buy a pocket like ORMO-PL. Subject resolved
The discussion revolves around using a Barracuda 7200.12 500GB HDD as an external disk via USB-SATA adapters. Users highlight the necessity of a 12V power supply for 3.5-inch drives, as the 5V provided by some adapters is insufficient for powering the drive's motor. The first suggested adapter lacks a 12V supply, making it unsuitable for the Barracuda HDD. The second adapter, which includes a separate power supply, is recommended for reliable operation. Users also mention the availability of enclosures specifically designed for 3.5-inch drives that come with external power supplies. Concerns about the practicality of using multiple power sources and the size of the enclosures are discussed, with a preference for compact solutions that utilize USB power.
TL;DR: 3.5-inch HDDs need 12V for the motor and 5V for electronics; "12V is used to power the engine." Choose a 3.5" USB 3.0 enclosure with its own power. [Elektroda, Anonymous, post #16884524]
Why it matters: This FAQ helps anyone repurposing a 3.5-inch Barracuda 7200.12 avoid underpowered USB adapters, data loss, and failed power bricks.
Can I use a 2.5-inch USB–SATA adapter to run a 3.5-inch Barracuda 7200.12?
No. 2.5-inch-only USB–SATA adapters lack 12V output. Your 3.5-inch drive will not spin up without 12V. Use an adapter or enclosure that supplies 12V. [Elektroda, marqqv, post #16884406]
Why won’t my 3.5-inch drive start without 12V?
The spindle motor needs 12V to start and run. Without 12V, the drive won’t move at all. As one expert put it, “12V is used to power the engine.” [Elektroda, Anonymous, post #16884524]
What does the 5V line on a 3.5-inch HDD do?
5V powers the drive’s onboard electronics, including controller ICs. Some designs also use it for actuator control. The forum notes 5V is for the electronics. [Elektroda, Anonymous, post #16884609]
Is the 3.3V pin on the SATA power connector used here?
Not generally. The thread states the 3.3V pin is present but unused on these drives and setups. [Elektroda, Anonymous, post #16884609]
Will USB 2.0 power a 3.5-inch HDD if I use two ports?
It’s unreliable. Some users report needing two USB 2.0 ports just to power certain setups, and disconnections can occur after spin-up. Use a mains-powered enclosure. [Elektroda, Anonymous, post #16884524]
What’s safer: a bare USB–SATA adapter or a full 3.5-inch enclosure?
A quality 3.5-inch USB 3.0 enclosure with its own power is the safer, cleaner choice. One recommended option was described as “great.” [Elektroda, Anonymous, post #16885107]
How much should I budget for a reliable 3.5-inch USB 3.0 enclosure?
Plan around 100 PLN for a decent, reliable enclosure that supports USB 3.0 performance and includes proper power. [Elektroda, ORMO_PL, post #16885096]
Do some 2.5-inch enclosures step 5V up to 12V for 3.5-inch drives?
Some have internal 5V→12V converters, but many lack the current capacity for 3.5-inch motors. Results vary and instability is common. [Elektroda, Anonymous, post #16884524]
Are cheap all-in-one USB–SATA/IDE kits safe for 3.5-inch drives?
Be cautious. A user reported the bundled PSU burned on first use, though the disk survived. Reliability varies widely with these kits. [Elektroda, djtommy, post #16885146]
Can I run a 3.5-inch drive without any enclosure?
You can, but you’ll add clutter and need another wall outlet. It also offers no physical protection. A proper enclosure is cleaner. [Elektroda, Anonymous, post #16885085]
How do I set up my 3.5-inch HDD as an external drive?
  1. Buy a 3.5-inch USB 3.0 enclosure that includes an external power adapter.
  2. Insert the drive, secure it, and connect SATA power/data inside.
  3. Plug the enclosure into mains and USB, then format if needed. [Elektroda, Plumpi, post #16885094]
Should I choose USB 3.0 or USB 2.0 for this drive?
Choose USB 3.0. It improves throughput and is recommended for easier portability and performance with 3.5-inch drives. [Elektroda, ORMO_PL, post #16885096]
What did the original poster decide after testing options?
They chose to buy a 3.5-inch enclosure like the one recommended, resolving the issue and avoiding underpowered adapters. [Elektroda, baszawez, post #16885229]
